Rough Country 3" lift.........yea or nea? - JeepForum.com
post #1 of 12 Old 06-22-2002, 05:24 AM Thread Starter
bigbrown
Any thoughts on this lift for a 94YJ, 2.5l? Price is right....$389 for everything; springs, shocks, TC lower, Pit Arm, etc....
94 YJ, 2.5l, 5speed, 60kmiles, Black. RC 3" Lift:)
bigbrown is offline
post #2 of 12 Old 06-22-2002, 08:04 AM
RichardL
The price is only right if it gets you where you want to be. What that means is that you are only saving money on the 3" kit if you want the jeep to sit up a little and fit 31's (good street set-up) or you want to run those tires for as long as it takes to wear them out and then upgrade($600 worth of rubber). Then you can decide if you want to go bigger, say 33's or 35's. The jump to 33's and beyond costs quite a bit more than just another set of springs or a SOA.
If you "eventually" plan on bigger tires, it may be better to save the cash and labor by skipping the intermediate step and spend money once. Your personallity will dictate. Go with what makes you happy rather than trying to save $50. You will end up spending less in the long run.
RichardL is offline
post #3 of 12 Old 06-22-2002, 12:29 PM
-D-
Seems like it'd be saving a lot more than $50. 3" is borderline but like 2.5" for example wouldn't need new drive shafts, and SYE. That's more like $450 savings. If you get a 3" lift and a 1" body lift + 1" MM lift it'll clear 32's and might not need too much of a TC drop.
You could do a lot on a rig like that and save up for the setup you find out you actually wanted instead. Learn the skills on a modest rig where you'll have to exercise them more then do an SOA or install a bigger lift afterwards. Well that's my plan anyways.
-D-
-D- is offline
post #4 of 12 Old 06-22-2002, 01:17 PM
Paulwpetrea
Paulwpetrea's Avatar
Well, if you are talkin' about savin' money ... I would go with a beefier lift. Don't get me wrong. I'm not knocking Rough Country. However, it's not the most durable lift made, by any means.
Here are just a few:
<a href="http://www.bds-suspension.com/" target="_blank">BDS</a>
<a href="http://www.rubiconexpress.com/" target="_blank">RE</a>
<a href="http://www.skyjacker.com/curtleduc.htm" target="_blank">SkyJacker</a>
<a href="http://www.trailmastersuspension.com/" target="_blank">Trail Master</a>
I have a pretty complete list of chassis lift manufacturers on my <a href="http://www.angelfire.com/ga/bigjeeplover/favorites3.html" target="_blank">links page</a>.
I personally suggest the BDS lift.
Paul
Paulwpetrea is offline
post #5 of 12 Old 06-22-2002, 01:56 PM
kidwired
kidwired's Avatar
I used a bds 3.5" w/ a tcase drop and ran 33"s fine, before I soa'd
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #6 of 12 Old 06-22-2002, 02:37 PM
JeepN87
How much did you guys get your BDS lifts for?
Nick
87 YJ 4.2L
JeepN87 is offline
post #7 of 12 Old 06-23-2002, 11:21 AM
my litte red yj
well i am thinking of the same i also own a 93 yj with a 2.5 i am looking for mosly height i use my for going back and forth to work no heavy off road there are no places to go off road localy if there were i would spend thousands on lift and tires for the price of$475 or so delivered that is a good deal for me also i am running 235.75 15 so it won't look to bad my 2ct's
my litte red yj is offline
post #8 of 12 Old 06-23-2002, 12:48 PM
hog
There appears to be alot of BDS fans here, so I have a question for you'all. BDS list there warranty as "This unique warranty proves our commitment to the quality and reliability of every product we make.
If you are the original purchaser of any BDS product and it breaks, we will give you a new part. Period.
The No Fine Print warranty does not include shock and stabilizer cylinders"
Please do not get me wrong, I like my BDS sytem (the shop that installed them is another story),and I highly recommend them. However, my springs (2.5") are starting to deform terribly-almost S shaped at this point--if I went back to BDS do you think they would work with me on replacements or do I have to "break them completely" before they are covered..
I know I have caused this problem as I use my jeep as a work truck on site (hauling materials, pulling out equipment,etc)and many would say I even abuse it. But that is why I have my jeep, and I need to correct this situation.
Thanks for any suggestions, experiences, etc.
Hog
hog is offline
post #9 of 12 Old 06-23-2002, 12:56 PM
AJ
Rc 3" lift gave me about 4.5. Clears 33's, works fine.
AJ is offline
post #10 of 12 Old 06-23-2002, 05:54 PM
not4pzn
I have the RC3inch,installed it two weeks ago,took about 9 hours,me and one other guy,and he is an experienced mechanic,(I'm not)It seems to be fine,I'm happy with it.I know there are better ones out there,but if money is the issue,and it always is,its a pretty good set up. I took Osburns advise,and used 2 1/2 degree shims,and everything seems to be just fine. I have no shimmy or vibration to speak of,although,they do not include longer sway bar arms,which I purchased from skyjacker for $87,quick disconnects.I think it all depends on what you are going to do with your Jeep,if your hard core,you might want the higer doller lifts,I think the old saying"you get what you pay for"holds true. Good luck!
87YJ,just getting started.....
not4pzn is offline
post #11 of 12 Old 06-23-2002, 07:58 PM
BzJeep
BzJeep's Avatar
Well we have not tested my Rubicon Express (RE) Lift yet but it looks wicked. It is a 4.5" kit (come 2.5") and sits at about 5.5 inches. Very good looking kit and comes with EVERYTHING, just need tools such as a torx wrench, pitman arm puller etc... The cheapest I found the kit for was 849.95 though. Kinda steap seeing that you can find lift kits like this for under 700. BDS is another good choice I have heard though. I alot of people go with it.
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #12 of 12 Old 06-23-2002, 08:00 PM
evilpsych
evilpsych's Avatar
hey speed.. post pics of your RE 4.5 kit.. i wanna see.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
Rough country 4" lift kit? bulrokyj YJ Wrangler Technical Forum 27 01-02-2013 06:24 PM
Rough Country 4" Lift vs. Tuff Country 4" Lift reecep14 TJ Wrangler Technical Forum 3 07-29-2010 02:25 PM
Rough Country 3.25" Lift rusty-rubi TJ Wrangler Technical Forum 4 07-30-2009 06:46 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
2" Rough Country lift kit khunter2 YJ Wrangler Technical Forum 4 02-08-2007 06:14 PM
