Rotting aluminum AX15 casing, ever seen this before? With pictures. - JeepForum.com
post #1 of 6 Old 08-11-2012, 03:27 PM Thread Starter
Alheim
Hey folks. I'm in the midst of a 4.0 swap, and while I'm at it I'm replacing the seals on my AX15 & transfer case, as well as swapping over to an external throwout bearing setup.
Anyway, on the bottom of the transmission, on a area that is normally covered by the transmission mounting plate (the 'torque plate'), I found a spot on the aluminum casing that was rotting / corroding away. Once I removed the torque plate I lightly chipped away at the aluminum until I had removed all of the flaking, then wire brushed the spot.
The corroded spot:
This is on the bottom of the AX15. Here you can see it relative to the rest of the transmission and transfer case:
I've never seen aluminum do this before. Any thoughts? How thick is the trans casing at the spot? Anything I should do to stop further corrosion?
Thanks for your time.
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #2 of 6 Old 08-11-2012, 03:36 PM
Jeepsr4me
Aluminum does corrode. And that spot there may hold salt and crud. Sand it down with some aluminum oxide sand paper and clean then paint with some good paint. That area would have already cracked if it was thin. So you got lucky enough to catch it.
Jeepsr4me is offline
post #3 of 6 Old 08-12-2012, 08:45 AM Thread Starter
Alheim
Thanks.
I suppose I knew aluminum can corrode but haven't seen it to this extent before. You're right, this was in a spot that had a ton of dirt & salt wedged in there, between the torque plate and the transmission.
Any paint suggestions? At the moment I only have Duplicolor primer & engine paint on hand.
Alheim is offline
post #4 of 6 Old 08-12-2012, 08:59 AM
Jeepsr4me
Get some self etching primer, after that what ever color you want.
I seem wings on aircraft have worse corrosion than that, on the inside structural member.!!!
post #5 of 6 Old 08-12-2012, 09:58 AM
lovett86
kinda looks like some one had heated that up with torches at one point for what ever reason
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #6 of 6 Old 08-12-2012, 11:04 PM
imstillatwork
can you get a closer, clear photo? that looks like something has been rubbing, or someone melted it. can't tell from the distance though. weird??
imstillatwork is offline
aluminum , ax15 , corrosion
BFG AT dry rotting and chunking Prot JK Wrangler Technical Forum 11 01-31-2012 09:58 AM
TJ head casing number Big4banger TJ Wrangler Technical Forum 2 08-06-2009 07:59 AM
Rotting Frame JACFF7 YJ Wrangler Technical Forum 2 06-01-2009 09:53 PM
Rotting Frame Brokn_jeep YJ Wrangler Technical Forum 6 07-08-2007 08:25 PM
Casing on differentials coolguycarlos TJ Wrangler Technical Forum 5 10-03-2003 10:44 AM
