rotor shield? - JeepForum.com
post #1 of 5 Old 07-18-2011, 09:02 AM Thread Starter
Unii
rotor shield?
will it hurt anything if I remove the guard that surrounds the rotor, I put it a tj unit bearing and i believe its the rotor rubbing. i even spaced the rotor with some washers and it still didnt help.
Unii is offline
post #2 of 5 Old 07-18-2011, 09:10 AM
jbolty
jbolty's Avatar
I don't have the details handy but there are certain years and or versions that have rotors with a different offset. So, maybe you don't have a matched set.
We did an axle swap on a friends tj a few weeks ago and put on the newest rotors we had but they dragged horribly until we compared the two sets and swapped.
As for the shield, I left mine out but plan on putting them back next time I have it apart. Mr Blaine tells me that that are thick enough to effect the caliper spacing.
jbolty is offline
post #3 of 5 Old 07-18-2011, 10:15 AM Thread Starter
Unii
so maybe if i get a tj rotor it will stop rubbing?
Unii is offline
post #4 of 5 Old 10-25-2013, 04:13 AM
bogleparsons
I know this is a necro but I just finished my CAD delete and TJ axle swap yesterday and my rotors rub the knuckles now
I didn't put my dust sheilds back in either, I had to put an 1/8 thick washer behind the rotors to keep them from rubbing.
Anyone know what year wrangler would have the rotors that may help this?
I may have to order some small spacers because I damn sure am not taking those hubs apart again.
Nevermind I think I found my answer here http://www.jeepforum.com/forum/f9/tj...rotors-361355/
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #5 of 5 Old 10-25-2013, 05:41 AM
alc60560
I don't use the dust shields. Took them off years ago
alc60560 is offline
Rotor shield placement MikeF622 YJ Wrangler Technical Forum 3 06-17-2008 10:46 AM
Bug Shield? AferVentus TJ Wrangler Technical Forum 14 06-10-2008 03:08 PM
Fan Shield SteveJcoYJ YJ Wrangler Technical Forum 11 07-26-2007 09:32 AM
With or Without the Bug Shield? SteelBlueTJ TJ Wrangler Technical Forum 17 08-27-2005 03:36 AM
BRA OR SHIELD WRANGLERX TJ Wrangler Technical Forum 16 05-18-2002 01:38 PM
