Rotor seizes when tire is torqued. What the? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rotor seizes when tire is torqued. What the?
Rough Country Deals at JeepHut.comExtremeTerrain GROUP BUY: Barricade Rear Bumpers/Tire Carr*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*
Unread 05-13-2014, 09:03 PM   #1
Rproject
Rproject's Avatar
1987 YJ Wrangler
Just installed a new caliper and rotor. Everything fit fine and is properly torqued. Everything moves perfectly, until ......... until I put on and torque down the tire. As soon as I tighten down the lug nuts everything locks up. Help?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote
Unread 05-13-2014, 09:20 PM   #2
TSEJEEPERS
New rims?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Unread 05-13-2014, 09:45 PM   #3
jbolty
jbolty's Avatar
almost certainly the wrong rotor. The old vs newer style have a different offset so it's probably jamming against the caliper. Compare the two. The difference is obvious but not so much if you see them separately
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 05-13-2014, 09:59 PM   #4
Rproject
Rproject's Avatar
1987 YJ Wrangler
I had this problem when I swapped out my 87 axle for a 95 axle. Figured I put the wrong rotor on so I put on the more shallow rotor. My caliper locked up and cause a fire so I got a new, loaded, caliper and new rotor for a 95. The new rotor is the deeper rotor. I *think* I have the wrong dust shield on. Working on getting the wheel bearing off now. After the caliper fire, the wheel bearing is being a pain to remove. Planning on replacing that as well. JIC.
1996 White ZJ
Unread 05-14-2014, 05:38 AM   #5
Rproject
Rproject's Avatar
1987 YJ Wrangler
Update:
Installerous moronicous strikes again. When I swapped out my '87 axles with 3:07 gears for '95 axles with 3:73 gears, I decided to use the wheel bearings from the '87 axles because they were cleaner. Last night I pulled the wheel bearing to remove what I thought was the wrong dust shield. Since I kept the bearings from the '95 axles, I compared them. Yup, the '95 wheel bearing is a different height than the '87 wheel bearing. Sometimes I could just smack myself at my level of stupidity for not checking the first time.
1996 White ZJ
Unread 05-14-2014, 10:32 AM   #6
superj
1987 YJ Wrangler
its ok man, who would have thought the same axle would have different bearings on the same model of jeep
Slow ride, take it easy
superj is offline   Reply With Quote
Unread 05-14-2014, 02:40 PM   #7
ROWA
ROWA's Avatar
It's a JEEP you got to expect the unexpected.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline   Reply With Quote
Unread 05-14-2014, 07:24 PM   #8
Rproject
Rproject's Avatar
1987 YJ Wrangler
Rebuilt the passenger's side and checked out the driver's side while I was at it. Everything is much better now.
1996 White ZJ
