rotated D44 axle with a 4in lift emergency brake problem - JeepForum.com
post #1 of 8 Old 02-13-2014, 09:25 PM Thread Starter
vortexflow2010
Hi,
I have a YJ with a Dana44 and 4in lift. the axle had to be rotated about 30-45 deg to line up the shaft.
the problem is that the E brake cable is too short.
I am wondering if I can rotated the drum brake backing plate by 90 deg to resolve the problem.
I have not taken a look at the unit yet to see if it is even doable.
Does anybody here knows if this could be done and if not what is the typical solution of the E brake?
vortexflow2010 is offline
post #2 of 8 Old 02-14-2014, 03:35 AM
jsawduste
2006 YJ Wrangler
Ahhh, 30-45 degrees to line up the shaft ? Assuming your talking about the driveshaft then you have more issues hen just the e brake.
Any pictures ?
jsawduste is offline
post #3 of 8 Old 02-14-2014, 04:42 AM
StanF
Tips
1) Fill out your Jeep Profile, in detail, especially for the non-stock parts, like the Dana 44
2) Post pictures, as recommended
StanF is offline
post #4 of 8 Old 02-14-2014, 10:15 AM Thread Starter
vortexflow2010
I attached a photo of the Jeep. I will attach more on the axle setup later.
Its worth mentioning that the axle is on and it works. It is just that the previous owner left the E brake lines hanging. Getting longer E brake lines seem to be difficult and I am left with one of two options.
- make my own using what ever cabling hardware I can find without braking the bank.
- Try to rotate the drum brake backing plate by 90 deg (if possible).
post #5 of 8 Old 02-14-2014, 10:51 AM
fratis
fratis's Avatar
While sitting static, if they just reach when you rotate the break mounting plates what happens when you go to wheel your jeep? If you want a suspension that works you need longer cables. This is another thing that SOA threads tend to leave off.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 8 Old 02-14-2014, 11:03 AM Thread Starter
vortexflow2010
You are right about the static vs extended.
rotating the plates( if it works) will only solve one problem of not having the e brakes warped around the axle.
Where do you get longer E brake cables.
-Is there a car model that would have a longer E brake lines that would fit a Jeep?
-Do you buy an E-brake lines and make your own?
post #7 of 8 Old 02-14-2014, 11:37 AM
fratis
fratis's Avatar
I first made my own. You will notice that the rear passenger-side is longer then the driver-side. I took the passenger-side and put it on the driver-side. I then welded two different outer sleeves together and replaced the cable itself to make up the rear passenger-side. When I did an axle swap I then went with a Lokar kit.
fratis is offline
post #8 of 8 Old 02-14-2014, 11:44 AM Thread Starter
vortexflow2010
That sounds good.
where did you get the longer cable from?
is there any car that has the same cable end (axle side) as the Jeep that you can easily swap?
brakes , dana 44 , e brake , emergency brake
