Roof Racks - JeepForum.com
post #1 of 16 Old 10-30-2013, 10:19 AM Thread Starter
dander88
Roof Racks
I have looked around a little bit here.. What roof racks off other cars have you put on your hard tops. I am going to go measure out a 95 Ford Escape today to see if it will fit. What about others?
dander88 is offline
post #2 of 16 Old 10-30-2013, 10:52 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
'99 Isuzu rodeo. It needed to be cut down a little but it still worked. No pics because I sold it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 16 Old 10-30-2013, 11:11 AM
superj
one from a cherokee will fit.
mine had holes like someone had put on on it in the past but since hte top is fiberglass, i filled the holes and didn;t put another rack on
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 16 Old 10-30-2013, 11:14 AM Thread Starter
dander88
Does anyone have pictures of the support they used on the roof racks. I was thinking, maybe just some strips of aluminum on the inside of the roof would suffice. Any ideas there?
dander88 is offline
post #5 of 16 Old 10-30-2013, 11:15 AM
superj
thats why i never put one back on my top. no support for a roof rack
superj is offline
post #6 of 16 Old 10-30-2013, 11:18 AM Thread Starter
dander88
I do a lot of skiing in the winter, main reason I bought the Jeep. So not doing it is not an option. There's got to be a way to make this work with proper support...
dander88 is offline
post #7 of 16 Old 10-30-2013, 11:25 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The rodeo rack had long wide feet that spread the load quite well. A thick strip of rubber on the inside would help.
post #8 of 16 Old 10-30-2013, 11:26 AM Thread Starter
dander88
Perfect thanks! Calling the scrapyard now to see if they have any!
dander88 is offline
post #9 of 16 Old 10-30-2013, 01:13 PM
fireguyl9
I installed Yakima Q towers on my hard shell. the large threaded knobs along with a flat washer works great. Caulked around the holes I drilled for bolts and ran a bead of caulking around underside of base before securing
fireguyl9 is offline
post #10 of 16 Old 10-30-2013, 01:57 PM
SeanB95YJ
How about getting (or making?) a VERTICAL ski carrier? they can go in a hitch receiver, bolt to the bumper, or clamp to a spare tire carrier.
I know I've seen em before, but don't know if there's a special name for that type of carrier
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #11 of 16 Old 10-30-2013, 03:06 PM Thread Starter
dander88
I went and got an 02 escape roof rack with the cross bars for 45.00. I am going to mount them with some either a rubber strip on the inside with some over sized washers or an aluminum strip with washers.. I will post pics when it is done. Thanks for the ideas..
dander88 is offline
post #12 of 16 Old 10-30-2013, 04:03 PM
RainShadow
Roof Rack
I would go a little more than oversized washers. Had a rack rip off the
roof of our old Cherokee when my wife drove it with our MTN BIKES still on
the roof ............ I would not use alum either. Just go to Home Depot/Lowes and look in their metal bin -- you will find something there.
You can also get a cheap metal cutter/saw at Harbor Freight to make it
easier than using a hacksaw and file. NOTE: do not hold the metal in your
hand while drilling either (my D____A_____ son did that) ....
good luck, Randy from Oceanside
RainShadow is offline
post #13 of 16 Old 10-30-2013, 04:49 PM Thread Starter
dander88
Thanks for the advice - I will be going to the store after work!
dander88 is offline
post #14 of 16 Old 10-30-2013, 11:30 PM Thread Starter
dander88
Well it is done - Picked up the 02 Escape Rack with the crossbars and got it installed on the hard top. Thanks to all for the advice. I ended up getting 2 metal strips that run on the inside of the jeep.
Here are the pics
dander88 is offline
post #15 of 16 Old 10-31-2013, 07:45 AM
StanF
Here are the pics
That looks awesome!
StanF is offline
