Rollover valve question for 87' - JeepForum.com
post #1 of 21 Old 11-17-2009, 02:04 PM Thread Starter
jchav74
1987 YJ Wrangler
I am doing some troubleshooting for an exhaust/gas smell I have been having with my Jeep. I have read up that an old rollover valve or connector may be a problem. The threads said it was supposed to be on the passenger side but I pulled the light assembly and the plastic panel under the tub at lunch and there is nothing under the passenger side. Is it located somewhere else on the 87' model?
jchav74 is offline
post #2 of 21 Old 11-17-2009, 02:10 PM
timatoe
timatoe's Avatar
It should definately be there. Are there any hoses at all in there? Maybe someone pulled the valve off.
timatoe is offline
post #3 of 21 Old 11-17-2009, 02:11 PM
Reverb
The rollover valve is pushed into the top of the tank on both sides. There is a pipe from each going to the evaporation cannister.
Reverb is offline
post #4 of 21 Old 11-17-2009, 03:25 PM Thread Starter
jchav74
1987 YJ Wrangler
I did not check on top of the tank. Do need to actually drop the tank or can I pull it out to inspect?
jchav74 is offline
post #5 of 21 Old 11-17-2009, 03:36 PM
timatoe
timatoe's Avatar
The part I was refering to is pictured in this thread... http://www.jeepforum.com/forum/f12/l...please-499519/
Mine was definately not pressed into the tank.
timatoe is offline
post #6 of 21 Old 11-17-2009, 03:59 PM Thread Starter
jchav74
1987 YJ Wrangler
Yeah, that was the part I was looking for but it is not behind the passenger side taillight on my Jeep. Tonight I will have to look above the tank and on the other side. You guys said I could trace the line back from the Canister under the washer fluid, right?
jchav74 is offline
post #7 of 21 Old 11-17-2009, 04:11 PM
Reverb
Well on my 258 with a plastic tank there are two that are in the top of the tank.
They are these
Reverb is offline
post #8 of 21 Old 11-17-2009, 09:20 PM
timatoe
timatoe's Avatar
Hmmm, I've got a steel tank, maybe thats the difference.
timatoe is offline
post #9 of 21 Old 09-21-2013, 01:42 PM
Barneysjeeppart
Yj roll over protection check valve
Barney's Jeep Parts LLC now carries the Rollover Protection check valve assembly for 87 - 90 YJ with 15 gal. tank. See our eBay store barneysjeepparts of call (740) 947-7030.
Barneysjeeppart is offline
post #10 of 21 Old 09-22-2013, 10:59 AM
SamzJeep
On my '88 YJ i have the roll over valve on the passenger side behind the tail light as mentioned above. On top of the tank are the breather vents (2 of them) that lead to the roll over valve. I replaced my vent grommets on top of the tank because it failed emissions (pressure test). Its been fine since.
SUPPORT OUR TROOPS
SamzJeep is offline
post #11 of 21 Old 09-22-2013, 01:35 PM
Barneysjeeppart
Good post SamzJeep. Barney's Jeep Parts LLC stocks those grommets also. (740) 947-7030. It's true that often symptoms of an issue (smell of fumes, etc) can be from one or many places. If I were taking the time and labor already, I would replace everything. Especially important where fuel is involved and safety is paramount.
post #12 of 21 Old 10-08-2013, 07:23 PM
Barneysjeeppart
Update on check valve note
The rollover check valve I have pictured is also for the 1976-1986 CJ with 15 gal. Steel tank.
post #13 of 21 Old 10-09-2013, 05:08 AM
grandboost98
My 89 only has one metal line going to the grommet. I assume that Tee and extra piece is removable ?
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is online now
post #14 of 21 Old 10-09-2013, 06:06 AM
Barneysjeeppart
YJ Valve Assembly
grandboost98 - You are correct. We offer this valve without the "T" for the YJ and at a reduced price. Just give us a call. The earlier picture is correct for the CJ and some J series vehicles. Sorry for the confusion of earlier posting. Growing pains of getting the business transferred from George's to Barney's.
post #15 of 21 Old 10-09-2013, 06:19 AM
grandboost98
Cool thanks.
BTW you may want to become a vendor here if you start advertising your products or youll quickly get the ban hammer
Pic of rollover valve? ylojelo YJ Wrangler Technical Forum 5 04-13-2012 01:30 PM
leaky rollover valve cyco YJ Wrangler Technical Forum 7 01-16-2009 12:43 PM
Rollover Protection Valve: Replace, Eliminate, or Possible Conversion/Equivalent...? YJ_Pat YJ Wrangler Technical Forum 1 07-29-2007 05:40 PM
rollover claytonandson TJ Wrangler Technical Forum 18 01-10-2007 12:04 AM
1988 YJ Fuel Rollover Valve inov8er YJ Wrangler Technical Forum 13 12-22-2006 05:38 PM
