roller rocker - JeepForum.com
post #1 of 8 Old 05-18-2007, 05:49 PM Thread Starter
bobbert350
bobbert350's Avatar
roller rocker
does anyone know if i could use chevy small block roller rockers instead of buying the ones that are made for the I6 jeeps....they are a dime a dozen just wondering if anyone has any info on this cauz im doing a 4.0 head swap on my jeep
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #2 of 8 Old 05-18-2007, 06:59 PM
93YJfalcon
Dang!!! If there was a swap like that I'd be all over it! Freakin' roller rockers for the I6 are about a billion dollars! I'll be watching this thread with much anticipation...
I'm off to start searching for a swap right now!
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #3 of 8 Old 05-18-2007, 07:05 PM Thread Starter
bobbert350
bobbert350's Avatar
well my buddie has roller rockers for his small block if i have bolts im just gonna have to puts studs in im gonna see if i they will work if they do il do a write up on it...cauz if everything works out like i think it will it should be 1/2 price for roller rockers
post #4 of 8 Old 05-19-2007, 02:35 PM
lilredjeep
First thing you need to do is check and make sure the raitio is the same before you just slap on a set of rockers. If raitio from fulcrum point is more you will crush the spring and snap the rocker, and/or bend your push rod. If it's less your valves will not open enough. Keep in mind, If your not going to fuel injection with the 4.0 head on the 4.2 motor, All amc rockers are the same raitio. So the roller rockers for the small block 301 V8 amc, will work on your 4.2 head. the hp goes up I know with 4.0 head swap, but a decent cam and a set of roller rockers, and opened up exhaust even with the 4.2 head will give you pretty good torque.
Dan
lilredjeep is offline
post #5 of 8 Old 05-19-2007, 07:37 PM Thread Starter
bobbert350
bobbert350's Avatar
Dan
thanks alot i looked into this already im gonna get the same everything out of them but thanks alot for letting me know just incase i didnt think of that...im hitting up 1.6 roller rockers
post #6 of 8 Old 05-19-2007, 07:46 PM
Austin_YJ
1987 YJ Wrangler
What? I can never understand your posts.
'87 YJ, 4.2L, MC2100, HEI, RE 4.5", 2" body lift, ford 8.8 locked, 36" Swampers, homemade discos, Superwinch x9
Austin_YJ is offline
post #7 of 8 Old 05-19-2007, 07:47 PM Thread Starter
bobbert350
bobbert350's Avatar
well i guess u have to be to understand them
post #8 of 8 Old 05-19-2007, 10:06 PM
fratis
fratis's Avatar
when i saw the rollers years ago you had to order them in quantities of four. i was going to order 4 and compare them to a cheap set for a chevy and physically see what the differences were so i could adapt the chevys for the 4.0. then return the grossly overpriced ones.
fratis is offline
Roller or Ball? LJameson TJ Wrangler Technical Forum 11 02-26-2011 02:17 PM
roller pin Ptr YJ Wrangler Technical Forum 2 02-17-2009 01:29 PM
Looks Of Plastic Rocker Vs. Real Rocker Guard jbpdog TJ Wrangler Technical Forum 12 06-01-2006 10:53 PM
Roller Rockers jonballi TJ Wrangler Technical Forum 0 03-21-2005 07:03 AM
roller lifters bucko81 YJ Wrangler Technical Forum 4 03-15-2004 10:26 PM
