-   -   Roll cage bars (http://www.jeepforum.com/forum/f12/roll-cage-bars-1548305/)
ericg2000 07-12-2013 10:34 PM
Roll cage bars
has anyone ever added these to their sport bar? it's tj style rear bars. i would like to get a set to and have them cut and welded to my existing sport bar.
i'd like to someday switch over to a frameless soft top and i'll need these rear bars to do that.
http://shop.jeeptubes.com/product.sc...4&categoryId=2
Tom95YJ 07-12-2013 11:11 PM
2 Attachment(s)
Just buy a Family style cage they are always going for around $150
kgb_m3 07-13-2013 12:46 AM
Where? Been looking for quite some time, people are either asking $400+ or no where to be found. Only one I've seen was out of a totalled jeep, they were still asking $150 for a bent set of bars :rolleyes:
kgb_m3 07-13-2013 12:54 AM
Tubes seem like a better idea. Keep the sport bar and add-on rather than replacing entire center section and losing sport bars.
Don't mean to thread hijack, but
you guys think Hobart 140 is sufficient enough to weld those pieces on? It's a 110v. Maybe using a torch in combination to pre-heat metal first, any thoughts?
ericg2000 07-13-2013 06:09 AM
I've never seen a family roll bar for $150 in the Houston area. There's a jeeps parts seller in Houston that has them from time to time but he asks a lot for them because he knows we want them.
I found a guy once who was willing to trade my for his but he didnt believe it just bolted on and was an easy swap so he backed out.
Anticanman 07-13-2013 07:23 AM
Giggityjeeper had some amalgamation of new and old roll cage strapped to his jeep. Too bad he's not on here very often anymore.
jeepster93 07-13-2013 07:33 AM
I used a 110v welder to install my roll cage. A hobart 135.
I have not "needed" the cage yet, haven't rolled, but it is stout and I trust it. Also used a lot of corner trusses and braces.
Anticanman 07-13-2013 07:36 AM
So you trust your trussed cage?
ericg2000 07-13-2013 07:37 AM
I'm not a welder but I assume when I get the tube set, they can be cut to length, then welded to my sport cage? Would you suggest painting before or after? I figure before, then go back and touch up where needed
jeepster93 07-13-2013 08:14 AM
I painted after.
The welder NEEDS really clean metal to produce a good weld and it makes a lot of heat, the heat will blister any paint within 6 inches of the weld. Get a good welding blanket too OR take the seats out and cover the dash with wet towels. You'll burn your jeep down otherwise...
Didn't even notice the trust trusses thing. I am a goob.
dillonjm 07-13-2013 08:22 AM
I went further, but I did what you speak of as part of my cage build:
http://www.jeepforum.com/forum/f12/cage-build-1321418/
superj 07-13-2013 08:33 AM
Check your surrounding areas for the cage. There were two here in coprus but I got one of them. U-pull-it might have one also
dillonjm 07-13-2013 08:35 AM
Yes, its sufficient. Especially if you use flux core.
.120 is only 1/8"
140mower 07-13-2013 09:42 AM
.120 is only 1/8"
Agreed, your welder has lots of power for this particular job, the next question is whether or not you can trust your ability to weld. All the power in the world won't make a better weld if the basics aren't met. If you're unsure, practice, esp. in the out of position welds that you'll find along the bottom and lower sides.
jserna 07-13-2013 11:49 AM
I have seen the TJ cages cheaper then the YJ cages. Get a TJ cage.
The time now is 08:07 PM.
