Rod knock...crate engine recommendations? - JeepForum.com
post #1 of 5 Old 11-10-2008, 04:49 PM Thread Starter
mike240
I need to replace my 258/4.2 carb motor in 90 Wrangler. Would like to know some experiences with those that have bought rebuilt crate motors. Rhino wants $1841, how are they? 4wd.com sells ATKs but I know nothing of them either.
any experiences would be helpful. I do not want to V8 it or put in other crazy mods. It ran great for 112k all original and that would fine for another 112K.
Thanks
mike240 is offline
post #2 of 5 Old 11-10-2008, 05:19 PM
UnderPar
1987 YJ Wrangler
ATK's are some of the best and come with a good waranty.
1987 - YJ 4.2 Auto -
1986 - Corvette
2001 - Explorer
2009 - A4
UnderPar is offline
post #3 of 5 Old 11-10-2008, 06:41 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Thanks
Is it a rod knock or piston slap that you are hearing? What is your oil pressure (hot)? If it is good when the engine is hot you may not have excess clearances in the bearings, but piston slap caused by poor clearances in the wrist pin area of the pistons. If you do not do high rev driving and it is piston slap that motor might have a bunch of miles left in it.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 5 Old 11-11-2008, 12:36 PM Thread Starter
mike240
Took it in to a shop for diagnostic due to irratic ocassional high reving. They said that was the Evap canister and EGR valve but they also said two rods knocking. The noise is only heard above 2000 rpm. I usually shift before then and have not noticed it. Oil Pressure is about 15 when hot.
mike240 is offline
post #5 of 5 Old 11-11-2008, 12:53 PM
Wif
Wif's Avatar
.. Oil Pressure is about 15 when hot.
At idle or at 2 - 3k ??
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
Anyone tried the Golen Engine Svc. 4.6l crate? ajrothm TJ Wrangler Technical Forum 15 08-02-2016 03:35 PM
Where to get a crate engine for 1997 TJ sport? The owl TJ Wrangler Technical Forum 10 01-27-2010 05:17 PM
Texas Engine Builder or Crate Motor? andrewbranch06 YJ Wrangler Technical Forum 2 10-04-2009 09:01 AM
GM 350 Crate engine or Golen 4.6L Stroker? DINOCAVE TJ Wrangler Technical Forum 35 06-12-2009 09:56 AM
loud knock knock knock...noise when backing up shea666 TJ Wrangler Technical Forum 5 05-30-2009 12:10 PM
