rod bearing disaster - Page 2 - JeepForum.com
post #16 of 27 Old 02-29-2012, 12:26 PM Thread Starter
riverhippy
I think i'll try to combine the two solutions. I'll replace the crank with a reman from autozone. they come with matched bearings. I'll buy a six banger motor and rebuild it this summer.
Oh...Que/louie...btw...my gf and her twin sister just posed for playboy....hah...i love my life.
thansk for all the help and insight guys.
riverhippy is offline
post #17 of 27 Old 02-29-2012, 12:54 PM
Louie4
I would have the motor purring within a week with that kind of incentive(s).
Was there a pun in there?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #18 of 27 Old 03-01-2012, 06:40 AM
Siva283
Pics or it Didnt happen. You can PM them to me so you dont get hit with the ban stick
Ask me how I know...
Siva283 is offline
post #19 of 27 Old 03-01-2012, 07:04 AM
Que89YJ
I am hearing blah blah blah Twins....blah blah blah....Playboy Bunnies! You know that we live pretty close by each other. Jobbie Nooners or maybe a trip to Putin Bay sounds like good road trips! The offer still stands; let me know if you need any help with the Jeep...or the twin sister
The lower crankshaft sounds like a plan. I remember you running the compression checks on the previous thread but I don't remember what you got but as long as they are fairly close then go for it and replace the crank. There is a place in Wyandotte called National Machined Engine(734) 281-6752. While the guy running it is ah....very unique, he is one of the best engine rebuilders in the state and the midwest. I can't recommend them enough. You might want to give him a call.
Also, like I posted Chris is a good guy to get in touch with if you are in a pinch and looking for anything as far as parts for your YJ.
Remember the 4.0l swap is a lot more then just an engine swap for us 4 angry squirrel owners. The rear end, trans, and motor mounts, and drive shafts need to be changed on the swap.
Que89YJ is offline
post #20 of 27 Old 03-02-2012, 02:02 PM Thread Starter
riverhippy
yeah...the compression was decent....should i replace the piston rings or anything while i got out the crank??
I dont have my boat anymore...but if you got a ride we'd love to join you at the nooner...check my fb page for pics of the twins at the playboy shoot...nick majeske
post #21 of 27 Old 03-03-2012, 08:57 AM
Que89YJ
No, if your compression is good and you are just trying to get it by for now then do the bearings and crankshaft. Putting the 4.0L in it will be some work. If you get a good doner powertrain cheap it might be worth it but it will require a different trans and drive shaft as well as the motor. Keep an eye out for cherokee drive trins and if you are serious that guy chris has about anything you could possibly want or need. BTW FB friend request sent. I got to see the pics!
Que89YJ is offline
post #22 of 27 Old 03-03-2012, 09:12 AM
UZI4U
If anything, you have an excuse to swap in a 4.0 now.
MCLMM
UZI4U is offline
post #23 of 27 Old 03-17-2012, 02:20 PM Thread Starter
riverhippy
avoiding a possible redisaster
this is one of the rod bearings that came with the crankshaft kit...is this gonna work?? or will it cause a problem?
post #24 of 27 Old 03-17-2012, 02:25 PM
pete1991YJ
It looks fine to me, what's the prob? they're suposed to stick out a bit before you put them in.
They make them slightly large so they "set" into the bearing bore when its all torqued back together.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #25 of 27 Old 03-17-2012, 02:32 PM Thread Starter
riverhippy
thanks pete...i wasnt sure..two stuck out and two didnt....ive taken this thing apart a few times and would like to avoid doing it again...lol
im a neophyte with this big of repairs so im relying on my brothers in jeepland for their input...
post #26 of 27 Old 03-17-2012, 02:45 PM
pete1991YJ
OK lemme clarify.. each half that sticks out, is supposed to go with a half that doesn't stick out. Hope that helps!
post #27 of 27 Old 03-17-2012, 02:55 PM
40dog
Check all the bearing clearances with plastigauge before you button it up and put the pan on.matched sets of bearings to the crank when sold doesn't really mean anything.Final check of clearance is done after assembly.Its a common practice in quality machine and engine work.If the pans still off you really should find out what your finished assembly tolerances are.sounds like your close to the end.
40dog is offline
crank shaft , hot chick , rod bearings , sex drugs rock and roll , tits
D35 disaster ????? claytonandson TJ Wrangler Technical Forum 16 01-21-2008 02:03 PM
Help! 97 TJ 2.5 Electrical Disaster! Woodyhfd TJ Wrangler Technical Forum 12 10-16-2006 10:09 PM
electrical disaster sandman'sjeep YJ Wrangler Technical Forum 16 11-07-2005 11:35 AM
Disaster ahead? Family TJ TJ Wrangler Technical Forum 6 04-12-2004 02:46 AM
Starter disaster CHSguard72 YJ Wrangler Technical Forum 4 03-25-2003 03:15 PM
