Quantcast rocker protection - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rocker protection
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 05-14-2006, 09:29 AM   #1
bananamane
rocker protection
I took off my factory steps from my YJ awhile ago and now i have like 5 holes were the step used to be. does any one know if they sell some kind of adhesive plastic thats black that looks like rocker guards. i dont feel like spending $200 for real rocker guards but i dont like the holes and they r starting to rust. i know they make a chrome one but i hate chrome. if someone could send a link it would be great. Thanks again
94 YJ-5spd-I6 4.0L-pair of KC daylighters on windshield bracket-warn front bumper-hella 500s on bumper-herculined tub-1" shackle lift- 12" sub
bananamane is offline   Reply With Quote
Old 05-14-2006, 01:15 PM   #2
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
just go buy some of that skid grip stuff (that was what my younger brother called it on the top of his skate board), and run it from fender well to fender well. I think you can pick this stuff up at any hardware store, and it is like tape and will stick on its own.
Clean the surface really good of all impurities first then this stuff should stick really well.
Also if you would like you could run it all the way to the bottom of your door and then fold it in over the top of the door step to add some traction and protection to your door entry.
Back Road Jeepin
BackRoadJPin is offline   Reply With Quote
Old 05-14-2006, 01:40 PM   #3
93YJfalcon
I just painted some 4 inch angle iron black, marked where the holes were and bolted it on. It gives a little mor eprotection too. One day you could weld on some steps.
ROCK OVER LONDON... ROCK ON CHICAGO!
http://dirtyfabworks.com/gallery.htm
93YJfalcon is offline   Reply With Quote
Old 05-14-2006, 01:46 PM   #4
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
I just used some 3"x5"x3/16" angle iron and made a set of rock rails. cost me maybe 75 bucks worth of material
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 05-15-2006, 06:19 PM   #5
bananamane
Thanks, i dont have a welder and i dont really like the look of the steps. but i like the flat look. how did u bend the metal under the tub or did it come that way? where did u get the metal ? home depot?
Old 05-15-2006, 07:01 PM   #6
mississippi_xj
The iron comes bent @ a right angle like that. It is called angle iron. It is measured like 5"x3"x0.25." You would call it "five-by-three quarter wall angle," If you went to the steel supply place.
You will likley have to go to a steel supply house. I don't figure it will cost you a bunch. I would look @ something like 1x3 angle for asthetic purposes.
-scotty
98 TJ 4.0 (Geared and locked on 2" coils and 33x10.50's), Former YJ/XJ/WRX Builder...
Contribute to my YJ spring rate info thread!
mississippi_xj is offline   Reply With Quote
Old 05-15-2006, 08:21 PM   #7
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
the amount of work is the same for 1x3 or 5x3, might as well go with the full size and get some protection out of. that's my thinking anyway
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Old 05-17-2006, 10:29 AM   #8
bananamane
did u guys just mount them using the holes on the side or did u make some sort of bracket for the bottom to mount to the frame? did u spray paint em or have them powdercoated?
Old 05-17-2006, 10:42 AM   #9
mississippi_xj
I spray paint everything that bolts onto my truck!
-scotty
Old 05-17-2006, 11:14 AM   #10
bokey
^^^^^^^^^same here ... As long as you prep correctly it'll look like sex. Here is the grip tape like stuff that was mentioned before...
I have the same issue as you do right now banana, and will probally use this as a temp solution until i can get actual rocker proctection.
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline   Reply With Quote
Old 05-17-2006, 01:14 PM   #11
92 Green YJ
Head Brewmaster
mine are just mounted to the body. what I did was to get a piece of 2" wide x 3/16" thick piece of flat bar. I clamped the rock rail to the body with the piece of flat bar clamped to the inside. then I drilled a series of 3/8" holes through the rock rail, the body, and the piece of flat bar. then i pulled the rock rail back down and finished welding the steps on, painted the door sill area behind where the rock rail mounts with truck bed liner (rust prevention) then bolted the rock rail up with grade 8 3/8" bolts and hardware. the bolts go through the rock rail, the body, and the flat bar. makes for a good strong mount.
Old 05-17-2006, 01:33 PM   #12
93YJfalcon
Be careful... If the adhesive on that griptape is as strong as the stuff that's on skateboarsd it will take off paint when you pull it off.
Glock Forum
