#1 | |
Rocker Panel Guards
Hello, I'm thinking about getting one of those Warn Rocker Panel Guards for my YJ. I am a bit concerned that if I have the guards installed, will it cause rust on the body a few years down the road? If so, any tips or advice on how to prevent that from happening?
M
#2 |
I think the only real solution to preventing rust is to move to the desert southwest.
You could mark where they will fit then mask off everything else and spray rust proofing before you install the Panel Guards. Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#3 | |
This is 100% method to rust proof, 3 years in Florida with not an ounce of rust yet, inside, between, or out. ![]() |
#4 | |
I did something similar when i installed mine, minus the grinding to bare metal part. All i did was clean it up real good, then tape off where the rocker guard was going to mount and sprayed the area with undercoating.
92 YJ 4cyl 5spd 3.5" BDS with 32's on 767's |
#5 |
That's not a bad idea. What if I just clean the body and spray it with rustollium and silicone the edge all around it?
#6 | |
Jello Puddin'
Me too, under the rockers and the rear corners.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
