Rockcrawling YJ Build - Page 3 - JeepForum.com
post #31 of 84 Old 02-21-2013, 12:00 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I missed the update before but I really liked those new bumpers. nice.
Originally Posted by Pawjob View Post
Well shes been a good jeep. Im getting ready the process of stripping her down to get ready to build a buggy out of her. Keeping the same engine,trans, and tcase.
My YJ running gear has been fine in my crawler
Going with a Ford Dana 44 65.5WMS, and a Ford 9in 65.5WMS rear. 4-5 front stretch, 4 link, 18in travel Radflow air shocks. 3-4 rear stretch tri 4 link,
9" is not enough for 43's. Your set up before was pushing the limits of safety and you are making the same mistake again. tires always in the air - will roll when it shouldn't. You should be thinking 108-110. Why design something that is so far off the norm? based on your wheeling pictures I think you are making a mistake. I'm not being a dick but I am concerned. You will be much shorter than anyone else on 40's much less 43s.
Yes, i dont want 60's two reasons, one clearance
If you are running 43's a 14 bolt barely affect clearance... much less a 60.
Theres no reason I cant run 43's on a D44, Ford 9in combo.
You should really do some research. Thousands of wheelers before you tried this stuff and failed, learn from them. between the wheel base and the 3/4ton axles... good luck. bring spare parts and pay your life insurance up.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #32 of 84 Old 02-21-2013, 12:17 PM Thread Starter
Pawjob
I still believe the 44's will handle the 43's just fine. Heres the deal, I can pick up 44's at the pick and pull for $220, or I can search CL and pick up a Dana 60 for $1500-2K. Yes they do cost that much. I can build a Dana 44 that just a strong as a Dana 60 and be into it less then a stock dana 60. It all comes down to cost, once in a while you can find the rear Dana 60's if I come across one Id pull it. I dont wheel with heavy throttle its not often my tac gets above 2500RPM. Spinning my tires and bouncing my front end around is something I dont do. And my wheel base i was shooting for was 105, but you have brought up a point. Ill stretch it a bit more and shoot for 108-110. I was hoping not to do any frame modification but I might have too.
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #33 of 84 Old 02-21-2013, 12:19 PM
fratis
fratis's Avatar
at some point its just best to build a buggy from scratch. ill never understand people who hack up a jeep until its all tubed out and the only thing left is a grill shell ziptied to the tubing. save the jeep and start with a tubular chassis. you will end up having a cool trail jeep, a DD, and a crawler; instead of a vehicle you cant drive on the road, thats overbuilt for trails and looks like *** and is a pain to make even minor changes to.
with 43s, 18" shocks, and 65.5" wmw you will definitely have to do quite a bit of frame reworking. the WMW will be a big issue. the front axle assembly in my avatar is that width and i had to mount the coilovers over the steering knuckle and i still needed to shave the bottom of the frame and notch the sides of it.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #34 of 84 Old 02-21-2013, 12:23 PM
skyj
I dont know how close you are to Kalispell MT but here is a sweet deal on a set on tons.http://montana.craigslist.org/pts/3615927145.html it might be worth the drive you probably couldnt build your d44 for this price.
build thread:
skyj is offline
post #35 of 84 Old 02-21-2013, 12:25 PM Thread Starter
Pawjob
But thats not what I want to build. I dont want a full tube buggy, I want to build my YJ into one. I do have a cool trail Jeep and DD its my 93 ZJ, the YJ sucks as a DD as it currently and I cant fit 4 adults plus gear to go out wheeling, beach, woods ect. Dont even get me started on what it takes to go camping for 4 days.
Pawjob is offline
post #36 of 84 Old 02-21-2013, 12:26 PM Thread Starter
Pawjob
That is a good deal but its passenger side drop I need driver.
Pawjob is offline
post #37 of 84 Old 02-21-2013, 12:29 PM
fratis
fratis's Avatar
was going off of this...
...stripping her down to get ready to build a buggy out of her.
again how can you do the above and leave the frame untouched?
fratis is offline
post #38 of 84 Old 02-21-2013, 12:33 PM
fratis
fratis's Avatar
fratis is offline
post #39 of 84 Old 02-21-2013, 12:40 PM Thread Starter
Pawjob
I never said leave the frame untouched I said with as little modification.
Pawjob is offline
post #40 of 84 Old 02-21-2013, 12:57 PM
JeepAddOnsChris
Vendor
JeepAddOnsChris's Avatar
You can run 106-107" without frame mods other than cutting perches. Probably a bit further than that.
This is assuming your running CrMo shafts. The difference with 37s with light alloy wheels and getting away with it on a D30 and 43s with heavy homemade beadlocks on a D44 and not getting away with it boils down initially to u-joints. Same u-joint as the D30, so that will break with tires that big. Could do 300M or Super Joints, RCVs or whatever else if you're not a daily driver, but then that puts the weak point on your R&P, which brings the suckage as far as a trail fix. Stock straight six, you're not going to be happy unless you gear very deep to turn those tires and the deeper you go, the weaker your R&P.
I'm running 44/9 built locked and loaded on 38s (77 F150). I feel as if where I'm at with that setup is my max tire size. I do hold back in some situations so I don't go busting u-joints or lockouts.
Agreed that front HP 60s are way overpriced and usually worth more than the POS that they came out of. Rear 60s are a dime a dozen, but I'd rather run a shaved 14b. You can easily get either for $150-200. I'm not a huge fan of the LP60 like skyj posted, but those can be pretty commonly found for under what the guy on CL is asking for it. Additionally, a FF14b is much easier to setup than a D70, parts are less expensive and that D70 is a dually axle.
For what you're going to spend in a full hydro steer setup, you can buy that front axle (doesn't have to be a 78-79 if you're creative). Run hydro assist and call it good unless you're planning on stretching the front more than the 4-5" you were talking about.
We are currently away from the forums and unavailable for quotes. Please contact our sales team at 800-388-8637.
Visit our site
Like us on Facebook
JeepAddOnsChris is offline
post #41 of 84 Old 02-21-2013, 01:14 PM Thread Starter
Pawjob
I was running 30 spline chromo shafts and I was running 37 12.50 16.5 GY MT/R's on custom re centered H1 wheels. They weighed 150lbs each corner. I agree you can find the rear 60 and 14bolt cheaper Ill look at picking one up when the funds become available. I would like to stretch out front as far as possible to give me the best approach angle. If I go to far I run into the steering box issue so I figured easy way around that is full hydro. Im not running the stock 4.0L, Im running the ATK 4.7L Baja Stroker and a Stak 3 speed tcase with a 2.97:1, and 5.22:1 low range. My current crawl ration is 92, I would like to keep it close to that and I found 5.38 gears would be my best bet. That would put me at 107. Thats why I want to build my jeep buggy ive put alot of money into the engine and case. The homemade beadlocks were an idea to save money, I found afew other bead locks that woulnt be too much and probably lighter. The other problem is where I wheel its super tight JKs with 65WMS have issues getting around the trees. I really dont want too much wider as ill be unable to go into the areas I want too. But If I have too i can narrow an axle if needed. One last note Im not looking at makeing this street legal this will be a trailered.
Pawjob is offline
post #42 of 84 Old 02-21-2013, 03:18 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
What you believe and what the truth is are two separate things. You can hope all you want and hum "I think I can, I think I can" all over the trails but it will not change the size of your ring gear, the thickness of your knuckles, the defection of the shafts or the u-joints. Go price out a locker, oversion shafts, crane knuckles and high steer, new innter C's.
You are going to be in $1100 on inner C's and knuckles with out high steer arms, shafts, u-joints, bearings, etc... Your $2500 dollar many man hour Dana 44 is till going to have a dana 44 sized ring and pinion.
No you can't. besides a Dana 50 is cheep and common. They are all dana 60 but the ring gear(slightly larger than a dana 44). For <$200 bucks you can have one at most any junk yard. Way easier and cheaper than putting thousands into a dana 44.
If you grab a newer sterling 10.25 the bolt pattern will match. These are also <$200 at junk yards. They are arguably stronger than a 14bolt and guess what.... you dont have to shave them. They have more clearance than a 14 bolt.. I think 1.5" or so.
Edit.... I might be on to something. Stock dana 50 and stock 10.25 from a super duty. way stronger than a 44/9. cheaper because they are undesireable.
Poke is offline
post #43 of 84 Old 02-21-2013, 03:19 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I got laughing typing that first part... just joking
Poke is offline
post #44 of 84 Old 02-23-2013, 10:58 AM Thread Starter
Pawjob
I'm going to do more research on axles. So when my zj is built and the funds are there I can find some axles. Ill scrap Tue 44 idea and are what I can find.
Pawjob is offline
post #45 of 84 Old 05-20-2013, 11:01 AM Thread Starter
Pawjob
Just finished up the body part of my buggy build, and took her out to see how i like the new body. Still need bumper ill build them here in a couple weeks. Then ill be working on building axles for my ZJ then ill be buying parts for the suspension/axle phase of the build.
Pawjob is offline
