Rockcrawling YJ Build - JeepForum.com
post #1 of 84 Old 10-16-2012, 07:36 AM Thread Starter
Pawjob
So I'm new to this forum so I thought I might add my build. Just to say HI and give others ideas on what to do to there YJ's. I built this with the intent of rocks and trails so heres the specs
History - Bought this jeep for 1700$ with only 106k miles even had a nice hard top and full doors. It was a in a wreck hit a rock at 50 mph. Frame was bent and needed new front fenders. Picked up a frame from a 95 2.5L YJ for 100$ and swapped everything over
Lift - +1.5in SOA using Rubicon Express springs and custom perches. Top that all off with Rancho 9000xl shocks. I wouldn't recommend them the shock body is way to fat and after 4 trips they are dented bad from the leaf spring plates. I will be replacing them soon haven't decided with what yet.
Tires - I picked up a set of 37 12.50 17R Goodyear MT/R's on MB72 black alloy wheels.
Steering - Tera flex front passenger knuckle. Built my own tie rod bar used 44in length of 1.5in molly tubing and Tera Flex tie road ends. Used the stock YJ drag link just cut it and sleeved it length.
Drivetrain - Stock 4.0l with AX-15 trans, Stak 4x4 3 speed mini monster box. 2.97:1 low and 5.22:1 Low. I would not recommend a Stak case for anyone. Company was horrible to work with, pops out of gear often. Kept the Dana 30 up front and added 30 spline molly axles with Eton electric lockers with 4.56 gears. Rear used a Dana 44 out of a 87 XJ and top that off with molly axles, Eton locker, 4.56 gears and disc brakes off of a ford 8.8.
Interior - I used the Smittybuilt seats and hurculined the whole inside. Makes easy to wash up.
Exterior - I built custom front and rear bumpers out of 5"x2"x1/4" HSS and in the front used a harbor freight winch plate to mount a warn 9.5ti winch. New bumpers are being build soon. Installed Metalcloak front arched fenders, rear corner guards, rocker armor and 6 in flares.
Ditch the hard top too hard to get on and off. So I replaced it with Rampage frameless soft top. Its a very good top would recommend it.
So it begins
Got a 982 on the RTI ramp just little more to get 1K
Looking sexy at Moab
Couple local trail pics
Thanks for reading hope this gives you ideas
Pawjob is offline
post #2 of 84 Old 10-16-2012, 07:58 AM
Eron
Nice looking build. Hope to get to that level soon. Thanks for sharing.
Eron is offline
post #3 of 84 Old 10-16-2012, 09:24 AM
zte87
GIVE IT THE ONION
zte87's Avatar
The yj looks great?? Where about do you live? The one pics looks a lot like walker valley, which is 40 mins from my house!
zte87 is offline
post #4 of 84 Old 10-16-2012, 09:59 AM Thread Starter
Pawjob
I live in Longview, most bottom pic is from Tillamook State forest on a trail called Canopener. The one up from that is Elbe Hills on the Busy Wilds trail.
Pawjob is offline
post #5 of 84 Old 10-16-2012, 10:24 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Nice we should wheel together some time I live out in anacortes wa!
zte87 is offline
post #6 of 84 Old 10-16-2012, 10:27 AM Thread Starter
Pawjob
Was thinking of an Elbe run Nov 17 I would camp up there 16th-18th
Pawjob is offline
post #7 of 84 Old 10-16-2012, 10:40 AM
Eron
And im right over in Port Townsend. Nice to know there are a lot of you guys around......
Eron is offline
post #8 of 84 Old 10-16-2012, 12:31 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
A few questions, maybe some pics will help me understand.
If yout shocks are rubbing on something, why not move the mounting points to a better spot. I was a show recently with a Ranchos' on display. I don't recall them having a larger body than any other long travel shock. Correct me if I am wrong or maybe we can help you mount them in a better place.
1.5+ SOA is a lot of lift with 37's and no stretch. How stable is that? I know on 35's and 3.5" of lift my jeep was unstable at steep angles. I see your front coming up a bit there. Have you been in other jeeps where you could compare the stability? Seems like to tall of a tire on a big SOA lift for the wheel base. IMO you would gain functionality by adding a few inches.
I have heard many people say those same things about stac... wont stay in gear, etc..
Do you have any trouble breaking axles or u-joints?
Poke is offline
post #9 of 84 Old 10-16-2012, 12:59 PM
fratis
fratis's Avatar
regular shock cans getting dented is a common thing with yjs and factory mounts. if you go with a monotube shock in the "can-up" orientation you wont have problems with that. you really need to build new shock mounting points front and back to take advantage of your soa. its never done.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #10 of 84 Old 10-16-2012, 05:27 PM Thread Starter
Pawjob
Shocks are in stock location working on moving them soon not whole lot of room up front. The Rancho 9000xl are alot bigger then a normal mono tube. It feels stable haven't really had any issues with stability other then very steep climbs if thats the case Ill suck the front end down. As for U joints im running standard YJ 1310 joints and the large wheel joints that you would find in the TJ Rubicon Dana 44 and have not broke any. Im easy on the skinny pedal.
Not full flex but you can kinda see whats going on
Pawjob is offline
post #11 of 84 Old 10-17-2012, 07:41 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
how is your suck down set up? this is something I would love to talk about. you don't see it on leafs very often at all. I understand that is because they don't unload. watching my roll video I think it would have helped me.
Poke is offline
post #12 of 84 Old 10-17-2012, 07:45 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
BTW that bumper looks HUGE... oddly big and its denfinately in the way for a rock crawler. Most rock crawlers would have a short bumper, the frame width so the tires can climb. That thing would get in the way basically everywhere I went.
Cut it down. Not only will that get int he way, it looks like your jeep has a monster 'stache
Poke is offline
post #13 of 84 Old 10-17-2012, 01:31 PM Thread Starter
Pawjob
When I first built the Jeep I built it for trails. The bumper was built to protect the stock fenders. Im planning on build a stubby bumper but I'm waiting for my welder to get back from the repair shop.
My suck down method is just two ratchet straps frame to axle tube by the perch
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #14 of 84 Old 10-18-2012, 01:40 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I have never heard of that. I think if I saw someone strapping down before a climb I would not want to wheel with them. between the waiting time and me wonder what else was not set up properly for the trails we were on.... I'd bail.
To other members, Don't get any idea's. 37's are tall with 1.5" SOA on a stock wheelbase. Your proof is in this thread. If you need to pull it down with straps to run the trails, you are not set up for the trails.
Poke is offline
post #15 of 84 Old 10-18-2012, 02:30 PM Thread Starter
Pawjob
I dont strap it down all the time. I did once after an attempt of a steep hill climb. I tried it didn't work still too steep for my short wheel base. Stability has never been an issue.
Pawjob is offline
