Rock Sliders With 2 Inch Body Lift - JeepForum.com
post #1 of 4 Old 10-10-2002, 07:27 PM Thread Starter
monkeywrench
IVE GOT A 2 INCH BODY LIFT ON MY ISLANDER I LIKE MY FACTORY STEP
BUT COULD PART WITH THEM IF I HAD TO
IS THERE ANY ONE OR COMPANY SELLING GOOD PROTECTION STRONG THAT WONT HANG DOWN 2 INCHES BELOW MY BODY BECAUSE THE FRAME MOUNT STUFF LIKE TOMKEN EXC GOES STRAIGHT TO THE FRAME WITH MAKES A 2 INCH SPACE BETWEEN THE BODY AND BARS THANKS PS SNOW IS JUST ABOUT HERE
PSS I WOULDNT EVER CONSIDER 3 INCH NERF BARS AGAIN I WASTED THE ONES ON MY TOYOTA ON A STUMP
jamie 92 yj 4 1/2 RE extream duty 2 body 35-12.50-15 4.56 arb frt rr yorkair warn 9000 zenon flares tomken tire rack 4.0 borla header magnaflow exhaust flexes awsome CURRIE 9INCH HIGH PINION IN THE REAR WITH DISC BRAKES ITS SHAVED TO just added TERA LOW 4 TO 1 TRANSFER CASE KIT
monkeywrench is offline
post #2 of 4 Old 10-10-2002, 08:59 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Without YELLING so much, I would suggest you look at SunPerformance and their rocker protection .. seems solid enough!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 4 Old 10-11-2002, 09:06 AM Thread Starter
monkeywrench
[QUOTE]Originally posted by NaeKid
Without YELLING so much, I would suggest you look at SunPerformance and their rocker protection .. seems solid enough! [
ANY OTHER IDIAS SO I DONT HAVE TO GIVE UP MY FACTORY RUNNINGBOARDS
post #4 of 4 Old 10-11-2002, 10:09 AM
NaeKid
NaeKid's Avatar
Re: Rock Sliders With 2 Inch Body Lift
Based on your original message .. you would be willin' to loose the factory steps .. so these would do the trick for you.
BTW: that is still YELLING, which is not appreciated here.
Silver
NaeKid is offline
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 04:34 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 07:38 PM
Does my body lift change the way my rock sliders install? bigken98 TJ Wrangler Technical Forum 13 04-10-2006 07:15 PM
Questions about Body Armor Rock Sliders Tispco TJ Wrangler Technical Forum 1 09-22-2005 05:45 PM
Body or Frame Damage From Rock Sliders? jpittman TJ Wrangler Technical Forum 1 01-02-2005 07:13 PM
