Rock slider mount advice - JeepForum.com
post #1 of 2 Old 05-06-2010, 07:14 PM Thread Starter
NateWithoutBeer
I just picked up some 3" x 5" 1/4" steel to make some easy rock sliders for my YJ and my buddy's TJ. The plan was to mount them with a piece of 2" 1/4" flat bar on the inside of the body as backing. We've found a problem on his ride, though...
As further evidence that Jeep ran out of good ideas when they began making TJs, we've found that the floor section of his body pan extends below the edge of his rockers (see pic) by about 1/2 an inch.
The way I see it we have two choices:
1) Notch out the 3" section of the angle steel to accommodate the floor dip
2) Mount the sliders about a 1/2" inch lower to accommodate the floor dip
I'm leaning towards option 1 as I don't like the idea of having a gap between the body and the sliders. Thoughts?
NateWithoutBeer is offline
post #2 of 2 Old 05-07-2010, 12:15 AM
wrangler76
My sliders are tied into the body mounts.... Between those and the bolts through the side I don't see them going anywhere even with the gap....If it really bothers you just weld a piece of 1/2" angle to take up the space....
wrangler76 is offline
Rock slider suggestions Sgalway JK Wrangler Technical Forum 24 01-13-2010 03:49 PM
D-30 Rock Slider mikesbeachhut TJ Wrangler Technical Forum 7 11-25-2009 01:39 PM
rock slider (body/frame mount) xxcyted TJ Wrangler Technical Forum 6 08-03-2008 08:21 AM
Rock Slider maintenance Los TJ Wrangler Technical Forum 4 07-01-2006 02:34 PM
OR_FAB rock slider step bars -Flip mount-able? (for step? BNovak TJ Wrangler Technical Forum 0 07-17-2004 05:54 PM
