Quantcast rock krawler steering - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rock krawler steering
Old 07-23-2007, 06:47 PM   #1
freedom5
does anyone have any pics of there YJ with rock krawler heim joint steering on it. I want to buy it, but first i want to see how it bolts on.
freedom5 is offline   Reply With Quote
Old 07-23-2007, 09:23 PM   #2
Muddy Rocks
Give me your email and I can send you the directions. I am putting one of these on my TJ This week.
Muddy Rocks is offline   Reply With Quote
Old 07-23-2007, 09:32 PM   #3
schwim
Hey there,
If you scroll down this thread a little, you'll find a couple posts from Joe Dillard where he explained the ins-n-outs of his steering setup for me.
thanks,
json
BOUGHT. Not Built.
schwim is offline   Reply With Quote
Old 07-24-2007, 12:23 AM   #4
speedracer2536
whoa when i get back from mexico in two days ill show you mine. do not run this steering setup i bought this setup up from them for my yj and i had one heimjoint shear off and the other pull completley out of the tierod. i had this steering setup for maybe 9 months when this happened and i had only about three wheeling trips on it and nothing hard core. the steering broke on an easy section that my stock steering had gone throu with banging on rocks unscathed. please wait for me to get you pics of it before you buy. i went to go try and use there warranty or lack therof and they wouldnt have it. needless to say the shop that i went throu to buy it cut rockkrawler out of the line. if you can hold off two days ill get them to you.
93 yj lifted locked and ready to rock
6.5"soa 35's lockers beadlocks,8.8
and some other junk here and there
www.krawltex.com
if your in austin look them up best guys to deal with hands down
speedracer2536 is offline   Reply With Quote
Old 07-25-2007, 09:57 AM   #5
speedracer2536
there you go you can see what im talking about
www.krawltex.com
Old 07-25-2007, 02:30 PM   #6
jeeepguy
jeeepguy's Avatar
If this is a DD rig, I would not recommend using heim joints. Stick to ball joints. Here is what I run and is a really good steering system upgrade for YJs...
JCROffroad 1ton steering
Great product and wonderful people to work with.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
Old 07-25-2007, 02:36 PM   #7
1 ton yj
I fixed it for you.
Originally Posted by jeeepguy
If this is a DD rig, I would not recommend using CHEAP heim joints.
I have DD'ed heim joint steering systems and have built steering systems for friends who DD them to this day. There is absolutely nothing wrong with using a correctly-sized quality heim joint in an every day rig. Look at Skyjacker, they use them in control arms for TJ's.
Anyone who thinks otherwise has either never actually tried it and is just regurgitating false information they read on the internet, or is using cheap econo junk like what RK uses.
I have broken 6 or 7 "1 ton" drag link ends in my steering system. Since switching to heims I have not broken a single joint nor have any developed any slop.
I have never seen the RK steering system but if their suspension systems are any indicator of quality (and I use that term very loosey with RK), then it is complete garbage.
1 ton yj is offline   Reply With Quote
Old 07-25-2007, 02:43 PM   #8
jeeepguy
jeeepguy's Avatar
1 Ton is correct in the sense thaqt heim joints are not inherently bad or anything like that. In many ways they are better than TREs. They are simply non-standard (no OEM manufacturer uses them, even in the most expensive vehicles) and require more general maintenance than TREs. Proven fact.
For the average person on this forum, TREs are more than sufficient, are more readily available if something grenades, cost less and are more maintenance free.
A 1 ton TRE is a proven, reliable, cost effective upgrade.
Doug Patton
Revelation 13:16-18
Think about it...
Glock Forum
