RIP Jeep? I hope not. Broken engine mount HUGE problem - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > RIP Jeep? I hope not. Broken engine mount HUGE problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 01-13-2012, 07:46 AM   #16
Hghgrad
I did the same thing on my drivers side a few weeks ago. Ended up stacking tack welds onto the end o the broken bolt to get it where I could grab ahold of it with a pair of Vice grips.
Both of them Came right out like that. Replaced with a brown dog mount and now it should never happen again.
Plan to do the passenger side one of these days when I get some extra cash.
I haven't wheeled this jeep at all since I swapped the 4.0 in, so mine just broke off from driving down the road.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline   Reply With Quote
Unread 01-13-2012, 08:14 AM   #17
ytowntj
I wonder why this happens? Bolts in the block loosen up and loose their preload and all the shear an moment forces go directly into the bolt boss...
Originally Posted by thrown_hammer View Post
There are two kinds of people... those that can drive in snow with an auto locker, and those that can't.
My build - Odd approach to 33's
http://www.jeepforum.com/forum/f22/o...h-33s-1307968/
ytowntj is offline   Reply With Quote
Unread 01-13-2012, 08:34 AM   #18
Brown Dog
Vendor
Brown Dog's Avatar
I've spent a lot of time studying this problem. On Wranglers, the failure is nearly always the driver side (barring unusual impacts). On Cherokees, the failure is on the passenger side. The length of the engine brackets on the driver side of a wrangler are longer than those on a Cherokee; the length of the driver side arms in either case are longer than the passenger side. The driver side brackets complicate the issue by being canted to provide space for the manifolds; the passenger side arms are at a right angle. The point is that there is asymmetrical loading on the brackets (weight x arm = moments of force). The driver side bracket of a Cherokee is just enough shorter to make the passenger side more vulnerable. There are a lot more considerations than I want to go into here. The bottom line is that it is very prone to failure. We sell a lot of brackets every week to repair this failure. At least one phone call every week or two starts out with "I have an unusual problem" ...no, you don't.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Unread 01-13-2012, 08:38 AM   #19
Brown Dog
Vendor
Brown Dog's Avatar
...and don't get me started on the ridiculous "clean sheet design" 4.0 that was introduced in Wranglers 2000. The bosses on that engine are bubblegum.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Unread 01-18-2012, 01:03 PM   #20
mrbriteside1465
Alright really great advice guys. Yeah I can see how extracting these bolts is easily the hardest part about this whole job. I definitely don't want to pull the engine if possible.
These brown dog brackets, is it safe to install them without the bolts that would normally go into the block that the old bolts are broken into? So I'm guessing you guys were talking about installing these brackets, and just leaving the old broken bolts as they are without trying to extract them. Seems like one of the best options, although I'll most likely give the extraction an attempt anyway. I don't want to compromise any safety in doing this though.
possman18360, I'm located in maryland between DC and baltimore.
mrbriteside1465 is offline   Reply With Quote
Unread 01-18-2012, 01:38 PM   #21
Brown Dog
Vendor
Brown Dog's Avatar
It is perfectly safe. Every week we sell brackets to someone who is using them as a repair for the problem you have. I always advise them not to waste the time of extracting the bolts, unless it looks like a pretty easy job. I have never had a report of a failure when using these brackets as a repair.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Unread 01-18-2012, 03:58 PM   #22
debord97
I used a small bit to drill mine out and then tapped square tip bit in the hole and they came right out. both sides of mine have been broke and both frame mounts have torn off the frame before. sucks.....
[COLOR="Red"]Red Jeep Club Member #608[/COLOR]
debord97 is offline   Reply With Quote
Unread 01-18-2012, 07:18 PM   #23
UltimatE
Resident Audio Guru
UltimatE's Avatar
I wouldn't hesitate to recommend Brown Dog to anyone. These things are beef.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 05-14-2012, 01:28 PM   #24
gatesjeff33
Are the stock bolts grade 5 or grade 8? I might upgrade mine just to make sure they don't snap off on me. Sounds like a pain in the *** project.
gatesjeff33 is offline   Reply With Quote
Unread 05-14-2012, 02:34 PM   #25
ashnken
Where in Md are you located? near Wv border?
ashnken is offline   Reply With Quote
Unread 05-14-2012, 06:21 PM   #26
superj
1987 YJ Wrangler
i need some brown dog mounts that adapt a 302 to the wrangler 4.2 spot, ha ha ha. i know how i drive a 302 so after i blow up the rear end, i don;t want the engine falling out.
Brown Dog, you guys ever thought of making adapter mounts to put other engines into the wranglers/cjs? the common motors like the sbf and sbc? i know novak and advanced make them but any slice of the adapter pie puts more money into your company
A lot of teenagers are people who express a burning desire to be different be dressing exactly alike.
Panties aren't my favorite, but they're right next to it...
No one is normal, there are just a lot of weird people with things in common.
superj is offline   Reply With Quote
Unread 08-17-2012, 03:04 PM   #27
FireMedic82
New addition to the site here. Just came across this thread searching for info and decided to add to the pile of broken Jeep mounts. I have a 2006 Rubicon and my driver's side engine bosses broke and bottom bolt sheared off a few days ago when I was turning into my carport and hit a small pot hole. Brown Dog mounts have been ordered. Really hope it does the trick.
FireMedic82 is online now   Reply With Quote
Unread 08-17-2012, 06:36 PM   #28
richharr
Try to get that snapped bolt out. The more holes you can use with the brown dog mount the better. My top boss looks the same way and the brown dog mount did the trick. Great part
93 4.0l 5 spd, 33s 4" lift
1. This forum requires that you wait 60 seconds between posts. Please try again in 1 seconds.
richharr is offline   Reply With Quote
Unread 08-20-2012, 07:19 PM   #29
FireMedic82
I've got the snapped bolt out. Thinking of having 2 studs welded in the place of the remaining bosses up top for a little added security. What's your thoughts on this?
Unread 08-20-2012, 07:21 PM   #30
Brown Dog
Vendor
Brown Dog's Avatar
Not worth the trouble. You are going to be more than fine as you are. I could probably give you a list of over a hundred customers who have recovered NONE of the original bosses and have had excellent results.
Brown Dog Offroad
91YJ 2.5
2" BL
3.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
engine , engine mounts , motor mount , shifted , transmission mount
