Ring and Pinion set - who to choose? - JeepForum.com
post #1 of 4 Old 11-18-2013, 06:28 AM Thread Starter
Rproject
1987 YJ Wrangler
I'm looking to upgrade from 3:07's to 4:10's. The problem is, I have no clue about ring/pinion manufacturers. I'm tempted to go with Crown as they make the OEM replacement, but I just don't know.
Insight from those who've done it on brands, options, quality?
Thanks.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 4 Old 11-18-2013, 06:40 AM
crackedcornish
since you haven't done any upgrade to the rear axle yet and you want to go to a factory available ratio, why not just swap your complete existing axles out for a set of factory 4:10's from a 4cyl equipped YJ
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 4 Old 11-18-2013, 06:54 AM Thread Starter
Rproject
1987 YJ Wrangler
While I can appreciate the sentiment, I know my axles are good and I've got a few buddies who know how to do gears - properly. I see no value in replacing good axles with unknown axles from a bone yard when I can get ring/pinion sets for the same money or less than complete axles.
1996 White ZJ
Rproject is offline
post #4 of 4 Old 11-18-2013, 07:20 AM
crackedcornish
I can understand your concern, but can't really recommend spending much money on the D35...by the time you buy the gears, bearings, and seals then whatever the cost of the install/set up, it would probably cost about the same to freshen up a JY acquired 4:10 equipped Explorer 8.8 with disc brakes and you would end up with a much stronger axle in the end
