Rim Size? - JeepForum.com
post #1 of 7 Old 09-05-2011, 08:54 PM Thread Starter
sjuice
Rim Size?
Im looking at getting the cragar soft 8's, I was wondering which size I should get?
Im planning on going with 33x12.5 tires would the 15x8 or 15x10 be better?
sjuice is offline
post #2 of 7 Old 09-05-2011, 08:56 PM
BriansCJ
1994 XJ Cherokee
15x8, less chance of losing a bead when aired down.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 7 Old 09-05-2011, 10:17 PM
Desert_Rampage
1991 XJ Cherokee
My thoughts, exactly.
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #4 of 7 Old 09-05-2011, 10:32 PM
Moto4x4
x3
Moto4x4 is offline
post #5 of 7 Old 09-05-2011, 11:34 PM
clarkjdg
clarkjdg's Avatar
x4
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #6 of 7 Old 09-06-2011, 09:32 AM
pasinbuy
I have a question. Why recommend 15x8 tires. If he gets rims for 33x12.5 tires isn't he then fine?
Are you guys saying that 15x8 airs down better than other tire and rim setup??
Or what am I not understanding here?
pasinbuy is offline
post #7 of 7 Old 09-06-2011, 09:42 AM
Sawicki4wd
If you have a narrower rim your less likely to when you air down to have a bead pop off. In running 35/12.5/15 with my stock rims and I can ride at 6-8 psi and not loose a bead. I actually had a tire blow out on me on my way home from work and I drove the 4 mile ride(very slowly) and made it home with out breaking the bead
Sawicki4wd is offline
Lower Control Arm bolt size? Has TuffCounty lift but I believe bolts are stock size. SolidBrass TJ Wrangler Technical Forum 10 11-09-2010 10:00 PM
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 03:36 PM
Shock size with 2" shackles... Stock size or longer? Obie95Sahara YJ Wrangler Technical Forum 1 11-12-2008 02:23 PM
wheel center hole size vs hub ring size thartman YJ Wrangler Technical Forum 8 10-27-2008 10:22 PM
Does any one know what size speakers are in my 97 sahara? Size? Watts? ect...? jeepcj7 TJ Wrangler Technical Forum 3 04-04-2004 01:56 PM
