Quantcast rim question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rim question
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 04-30-2009, 11:55 AM   #1
jerseyrider1119
rim question
I cant really find the answer to my question but maybe someone on the forum will. I want to run a 33x12.50-R15 or 35x12.50-R15. Im not sure what rim size i need? 15x7, 15x8, 15x10 I dont know.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline   Reply With Quote
Old 04-30-2009, 11:58 AM   #2
blue1989yj
A wheel with 8" width is what I would recommend. So 15x8 out of your choices. Some here have used a 7" width with no issues, however you may run into them if you are airing the tires down for offroad use.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline   Reply With Quote
Old 04-30-2009, 12:29 PM   #3
TheNewbie
Doesn't a narrower rim allow you to air down more since there is more pressure of the bead? So wouldn't a 7" be better for airing down than an 8" rim?
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
My build thread...
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline   Reply With Quote
Old 04-30-2009, 02:30 PM   #4
littleredjeep
The problem with a 7" wide is the back spacing of the rim. They usually rub on the leaf springs in the front. That is why most people go with 8" wide rim, then they can get I think 3 1/2 to 4 inch backspacing. I believe that is right. Someone correct me on the backspacing.
littleredjeep is offline   Reply With Quote
Old 04-30-2009, 02:41 PM   #5
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
I believe you're correct on the 7" rim and backspacing. they just don't make one with enough. I think the norm would be 3.25 or 3.75 backspacing.
The problem I ran into is that none of the tire shops near me would mount the 33's on a 15x8" rim. I'm sure I could have searched around more but most places wouldn't run the risk of mounting them.
I ended up with 15x10".
LB
_____________________________________
I own a Jeep, it's red and has big tires
Radical Pictures
lbsnowryder is offline   Reply With Quote
Old 04-30-2009, 06:35 PM   #6
Axl Jack
^ Ha, thats pretty dumb. I run a 32x11.5 on a 15x8 and love the look.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline   Reply With Quote
Old 04-30-2009, 06:54 PM   #7
AbbyNormalYJ
I ran 15x7s with 31x10.5R15s on my YJ and they rubbed the leafs at full lock. I ordered 15x8s with 33x12.5R15s with 3.75 BS and they fit perfectly, just missing the leafs. This set-up required 6" flares. BTW R&S Strauss will mount anything.
AbbyNormalYJ is offline   Reply With Quote
Old 04-30-2009, 09:18 PM   #8
michaelkkirk
15 x 10 with 33 x 12.5's and 7 inch flares.. no rub
michaelkkirk is offline   Reply With Quote
Old 05-01-2009, 12:30 AM   #9
lbsnowryder
The 32" tire is 1" narrower which is about all the difference it takes to rub on the leafs when turning.
I'm not sure of your point but you can't compare the two different tire sizes and rim sizes.
LB
Radical Pictures
Old 05-01-2009, 08:52 AM   #10
Lendo
I run 33x12.5 on 15x10 rims
Lendo is offline   Reply With Quote
Old 05-01-2009, 11:05 AM   #11
Axl Jack
No, I meant its dumb that the tire shop wouldn't mount 33'x12.5's on an 8 inch width rim when that's predominately what most guys run without issues.
Glock Forum
