Right Turn Signal Stuck? - JeepForum.com
post #1 of 3 Old 09-30-2010, 04:39 PM Thread Starter
Jakerdood
When I turn on my right turn signal, the green arrow in the dash just stays lit instead of blinking like normal. I checked outside the car to see if it was just the dash light but unfortunately, the right rear turn signal just stays lit and the side and front right turn signals don't even work. I don't know if its the bulbs in the front two that don't work or whatever is wrong with them.. but is the turn signal stuck in some way and can it be fixed?
Jakerdood is offline
post #2 of 3 Old 09-30-2010, 04:43 PM
kahanabob
its telling you there is a bulb out on the right side....could be front or rear....
kahanabob is offline
post #3 of 3 Old 09-30-2010, 04:45 PM
Gearhead231
Yeah this happened to me. Check your ground and change your bulbs. Should be a easy fix. Was for me.
Cherokee Creto-This is my cherokee... there are many like it but this one is mine, I will love my cheroke form the day of ownership untill the day it dies, I promise to modd it and beat it after said mods... i promise to treat all other cherokee owners as family even though they are complete strangers.... and promise to jeep on forever
Gearhead231 is offline
fix , parking light , stuck , turn signal , YJ
Turn Signal Dash Light Stuck On Jesse_87 YJ Wrangler Technical Forum 22 01-22-2017 01:39 PM
Turn signal light stuck on bikerman02 TJ Wrangler Technical Forum 7 11-19-2009 06:27 PM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
LEFT TURN SIGNAL DISPLAY STUCK GENE TJ Wrangler Technical Forum 2 03-15-2002 09:33 AM
LEFT TURN SIGNAL DISPLAY STUCK GENE TJ Wrangler Technical Forum 3 03-05-2002 02:30 PM
