The right slave - JeepForum.com
post #1 of 6 Old 06-02-2010, 12:30 PM Thread Starter
Rambo1967
The right slave
I need an internal slave for my jeep. Both the lines that come off the slave(one from the master and the other is a bleeder) come out the same place thru a rubber boot. Every slave that I look at online or in a parts store show the slave for my jeep with the lines coming out in two different directions. The one for the 4 cyl(i have a 6) shows the lines like I need they come out the same hole with the rubber boot.
This is the one they say I need...
NAPA Online
how pray tell would I get the lines which come out each side to go thru the rubber boot that's on one side? Any advise appreciated. Thxs
1990 wrangler 5 speed original I believe
Rambo1967 is offline
post #2 of 6 Old 06-02-2010, 01:20 PM
monkeyhouse
NAPA Online
YJ's started coming off the production line with ax-15's in march of 1989, so that sounds like you have the stock transmission. Looking at Napa's site, you should use part number NNC 37912, it does state it's for an AX-15. It looks like the one in mine and mine both come out the same spot of the transmission. That looks the same as my slave in the picture on the napa site. You could always call Novak or advance adapters and verify, they know their stuff when it comes to the ax-15. If I'm not mistaken, the ba-10 slave is the same one(internal).
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3 of 6 Old 06-02-2010, 01:46 PM Thread Starter
Rambo1967
Thanks for the reply. I'll give it a shot. Still a little confused on how to get the lines together looking at the part you said. They can be losened and moved around to where I need them? They need to be one on top of the other to go thru the rubber boot
Take a look at this pic
NAPA Online
I can manuver the lines on the slave u showed me to look like this?
post #4 of 6 Old 06-02-2010, 06:54 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
same thing happened to me. when i ordered a slave from advanced auto the slave came and the lines didnt even line up right. you can actually take out the lines from your old slave and reuse them in the new one.. easy to do and works.
Thomas
-1987 YJ
Tompatt is offline
post #5 of 6 Old 06-02-2010, 07:57 PM Thread Starter
Rambo1967
Old lines are junk. Hmmm back at square one. Auto parts stores are dumbfounded when I ask for the lines for the slave. Who can I call to get the right part for my jeep? Things just sitting here...calling me
post #6 of 6 Old 06-02-2010, 09:46 PM
monkeyhouse
advance adapters or novak.
94 YJ slave tab Roadyy YJ Wrangler Technical Forum 10 03-19-2010 01:10 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 11:26 AM
need a slave for a 94... Spigger73 YJ Wrangler Technical Forum 2 09-21-2008 02:22 AM
master slave cyl. to slave clutch hose gfortier YJ Wrangler Technical Forum 0 09-16-2008 08:37 AM
Slave out, more ?'s sentinal02 YJ Wrangler Technical Forum 12 07-09-2004 01:04 PM
