Right rear body mount, where's the nut? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Right rear body mount, where's the nut?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
View Poll Results: I should not have checked poll.
trying to get out of this 0 0%
I don't know how to delete it. 0 0%
Voters: 0. You may not vote on this poll
Unread 09-10-2013, 06:11 PM   #1
icfman
I'm a new jeep owner: I had to remove the Right rear body mount to install a new spring shackle kit. After getting the shakle kit reinstalled. I tried to replace the mounting bolt, but what ever the bolt was originally threaded into can not be found. It appear to me the "nut" is inside a boxed in area with no way of getting inside! AND maybe I'm the "nut" because I can not see something that is obvious to everyone else. Thanks!
icfman is offline   Reply With Quote Quick reply to this message
Unread 09-10-2013, 06:47 PM   #2
plym49
You have to cut an access hole. The nutsert has lost its purchase on the body and it is spinning on the bolt.
Cut a tee-shaped hole - an upside-down tee. The bottommost horizontal cut should be about a half inch or more from the bottom edge of the body, then about a half inch high. Once that is done, you can see inside and judge if and how much to cut for enough vertical clearance to get tools inside.
When you put it back together, plenty of neverseize on the threads and spray lithium grease all over the inside of the cavity.
Then, cut a patch to cover the hole and rivet it in place so you can easily get in there again next time. Weld the patch back in if you want the body to look mint.
Some guys try this repair from underneath and feel free to do it that way if you prefer.
Just remember that regardless of how you cut a slot for access, you want to be well above the inner floor that the nutsert sits on. Otherwise you will booger up your tub.
plym49 is offline   Reply With Quote Quick reply to this message
Unread 09-10-2013, 08:35 PM   #3
icfman
Thanks, this jeep world is something else! At least I wasn't overlooking something!
Unread 09-10-2013, 08:44 PM   #4
plym49
NP. Looking at the picture you posted, you can start by using a hole saw to drill a 1" hole. This lets you see inside to figure out how much you need to remove to get your tools in there.
The hole, vertically, would be on the center line of the body mount.
Horizontally, it would be halfway between the top of the red circle you drew and the bottom edge of your white tub.
Even better, start with a 1/4" hole.
You want to make sure that your access is within the enclosed metal box on the other side; everything is in there but you do not want to mess up the top, side or bottom edges of that enclosed area.
Unread 09-10-2013, 09:44 PM   #5
coolin4u
remove the plastic from in the whee lwell and cut from the inside,i have even used a chisel to cut the metal,you can access it there and then just seal it up the best you can to keep moisture from causing future rust,replace the plastic in the wheel well and no one will ever see you were in there
coolin4u is offline   Reply With Quote Quick reply to this message
