Rhino Lining Rims - JeepForum.com
post #1 of 14 Old 02-07-2010, 07:35 PM Thread Starter
willsyj
Rhino Lining Rims
has this been done before. i want to do it to my rims that i just got
94yj-2.5-2inch bl-1inch shackles-4inch RC lift-Aussie locked front-8.8 limited slip-kc lights-4:88's-33 baja-rhino lined tub.61cj-5-current restoration
willsyj is offline
post #2 of 14 Old 02-07-2010, 07:59 PM
XJ_AJK
1992 XJ Cherokee
Sure it can be done, but if you just want them to be black you should think about getting them powdercoated.
XJ_AJK is offline
post #3 of 14 Old 02-07-2010, 08:05 PM
MJMPC
I think Rhino Lining would give you trouble when you bal the wheels powder coating is the way to go.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 14 Old 02-07-2010, 08:06 PM
wish_bw
I would have to agree just get them powder coated it will look alot better
wish_bw is offline
post #5 of 14 Old 02-07-2010, 08:08 PM
Aero540t
1981 CJ7
spray paint...spray paint.
Looks good on stock wheels, and easy to fix scratches. Bedliner would be excessive for this job. My exterior and interior is bedlined and if the wheels were too it would just be way too much.
Aero540t is offline
post #6 of 14 Old 02-07-2010, 08:32 PM
H_Swank
X-2 Spray Paint. I have done numerous sets of rims with rattlecan, and they turned out GREAT. And to clean them, get the foaming tire cleaner.
Rhino lining them I would think it would give you the death wabble from hell, and you would put alot more stress on your axles and everything cause it would add unneeded weight. Just my
1991 YJ, Powered by a 97 TJ 4.0L AX-15 tranny, NP231 xfer
2005 WK, ALL Stock
"Never trade the thrills of living, for the security of existence" Live and love as if its your last day!!
Life is no fun unless, you take the path with the most resistance. -ME-
H_Swank is offline
post #7 of 14 Old 02-08-2010, 06:39 AM
paidfor
1987 YJ Wrangler
x-2, rattle can.
paidfor is offline
post #8 of 14 Old 02-08-2010, 08:35 AM
mrspradlin
it wont be as bad as they say for causing to be out of ballance. Just the min they put a tire on it will screw it up big time. Every time you rub something it has a very strong chance of ripping off. I would check around for a good powder and ask them how much to do them.
I took a set of rims to get powder coated wrinkle finish black and it was about 15 per wheel plus tax.
2013 JK Unlimited Freedom Edition
4" superlift 35s
mrspradlin is offline
post #9 of 14 Old 02-08-2010, 09:05 AM
XJelvis
I'd stick with spray paint as well. I'm planning to try some Duplicolor wheel paint this spring. I read in another thread that the graphite color looks very nice.
94 YJ, 2.5L, 5sp Sold.
97 TJ, 4.0, 5sp Sold.
01 XJ, 4.0, Auto
XJelvis is offline
post #10 of 14 Old 02-08-2010, 01:03 PM Thread Starter
willsyj
thanks for the replies. i guess i shouldn't do it, ill just sand blast them and spay paint them
willsyj is offline
post #11 of 14 Old 02-08-2010, 01:42 PM
Exparrot
Exparrot's Avatar
Don't even bother with sandblasting. If you use enough elbow grease or a wire wheel on a drill, you can get the majority of the crap off the wheel.
Rustoleum rusty metal primer and 3 coats of Professional Flat Black did the trick. 5 years later, I haven't had to retouch them except to cover up where the wheelweights used to be.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #12 of 14 Old 02-08-2010, 02:17 PM
H_Swank
I agree with Exparrot, a little elbow grease, primer, and paint.
2005 WK, ALL Stock
H_Swank is offline
post #13 of 14 Old 02-21-2013, 12:10 PM
Camfran33
I was wondering about that x-2 paint and where i can find it and also if it would last long?
Camfran33 is offline
post #14 of 14 Old 02-22-2013, 02:06 PM
timatoe
timatoe's Avatar
Good on you for searching and finding a thread that has what you're needing.
I'm assuming you were refering to this?.....
Originally Posted by paidfor View Post
x-2, rattle can.
If so there's no such thing as "X-2" paint. What he was saying was in reference to.....
As in "I'll second that opinion" = X's 2.
So the long and short of it is, they were simply saying to buy cheap rattle can spray paint to paint the wheels, because #1 it's cheap, #2 it's easy to touch up especially if you play in the rocks.
timatoe is offline
Rhino Lining danielgoforth TJ Wrangler Technical Forum 8 11-07-2007 09:09 PM
Rhino Lining USCGTWEET TJ Wrangler Technical Forum 11 06-27-2007 07:41 AM
Rhino Lining samger2 TJ Wrangler Technical Forum 5 10-27-2005 07:20 AM
Rhino Lining? headin4red2 YJ Wrangler Technical Forum 13 05-05-2005 06:04 PM
Do it yourself rhino lining? wazzufox00 YJ Wrangler Technical Forum 1 12-08-2003 10:27 PM
