Rheostat/cab light question. - Page 2 - JeepForum.com
post #16 of 20 Old 11-14-2013, 06:08 PM
Que89YJ
Check the fuses.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 20 Old 11-14-2013, 06:32 PM Thread Starter
beakerbload
1987 YJ Wrangler
Originally Posted by Que89YJ View Post
Check the fuses.
That was the first thing I did, then took out the rheostat, cleaned, reinstalled, checked the fuses again after reinstall, removed the rheostat, jumped the wires, checked the lights, checked the fuses again. All fuses are good as far as I can tell.
beakerbload is offline
post #18 of 20 Old 11-14-2013, 08:11 PM
Que89YJ
You need a meter or test light to go on from here.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 20 Old 11-15-2013, 11:10 AM
bpounds
bpounds's Avatar
You need a meter to check fuses. They can easily be blown and visually look okay.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #20 of 20 Old 11-15-2013, 01:48 PM Thread Starter
beakerbload
1987 YJ Wrangler
Fixed it. Turns out it wasn't the rheostat at all. It was the headlight/parking light switch, a much cheaper fix. I hadn't noticed my running lights were out. Once I did I researched that and found that switch to be the problem. Pulled one out of a junk yard for 6$, popped it in and all is well.
