Rheostat/cab light question. - JeepForum.com
post #1 of 20 Old 11-12-2013, 07:12 AM Thread Starter
beakerbload
1987 YJ Wrangler
So I believe my rheostat as taken it's last road trip, and I understand one can jump the wires on the back to just keep the instrument panel lights on full, which is what I had them running at anyway. The question is, my dome light in the back of my hard top is connected to this as well as the cab light under the dash by the e-brake. If I jump the wires will these remain on as well when the headlights/parking lights are engaged?
It's an 87 if it makes any difference.
beakerbload is offline
post #2 of 20 Old 11-12-2013, 09:21 AM
Que89YJ
Que89YJ is online now
post #3 of 20 Old 11-12-2013, 12:58 PM Thread Starter
beakerbload
1987 YJ Wrangler
I intend to buy a new one, but I was hoping to use the wire jump fix until I felt better about shelling out 100$ on a tiny switch. I guess I'll pull the dome light/cab light plugs until I get a new one or clean up mine. Dash lights are much more important that cab lights for me.
Also, the google link is for a different part, looks to be the hi/lo beams switch. Thanks for the link to the service manual.
post #4 of 20 Old 11-12-2013, 01:04 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Check part outs in the classified section. Better than searching through the junkyard for a Yj and shipping will be cheap.
Luck Favours The Prepared
Anticanman is offline
post #5 of 20 Old 11-12-2013, 01:13 PM
Siva283
I had to go to ebay to get my rheostat. Got it for 25$. Make sure your search specifically for the rheostat switch. Otherwise you will get the hi/low beam switch as you saw.
Ask me how I know...
Siva283 is offline
post #6 of 20 Old 11-12-2013, 01:26 PM
Que89YJ
Cfoffroad.com
He will have one
Fault codes:
Mean Max pics of everything:
No Start:
post #7 of 20 Old 11-12-2013, 02:08 PM Thread Starter
beakerbload
1987 YJ Wrangler
Yeah, I've never seen a YJ in a junk yard around here. at least not with anything but a rusted out frame/tub. thanks for the input.
post #8 of 20 Old 11-12-2013, 03:35 PM
bpounds
bpounds's Avatar
I think wiring around that rheostat is a pretty good idea. If you upgrade your dash gauge lights to LED's, the rheostat no longer functions anyway. And those brighter gauges are very nice and an easy mod.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #9 of 20 Old 11-12-2013, 03:39 PM Thread Starter
beakerbload
1987 YJ Wrangler
I'm planning on doing the LED's anyway, I may just wire around anyway unless I can get a rheostat cheaper than I can a good dome/cab light switch.
post #10 of 20 Old 11-12-2013, 03:42 PM
Old4X
1990 CJ7
I added some gauges that have LEDs. They were too bright when wired into my lighting circuit. I just took some resistors and mixed and matched till I got what I wanted for light output. Very easy to do.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #11 of 20 Old 11-12-2013, 08:28 PM
brentd711
Here's the jumper wire positions you need if the switch is bad.
brentd711 is offline
post #12 of 20 Old 11-13-2013, 05:36 AM
Que89YJ
Try and clean the one you have. use some contact cleaner on it first.
post #13 of 20 Old 11-13-2013, 06:21 AM
fishadventure
If it doesn't clean up, you can get a pretty inexpensive pull-out style 'universal' headlight switch with the same functions. it mounts in a 3/8" hole; I think a simple homemade sheet metal delete plate riveted over the factory switch opening will do the trick. There is no way I would spend $100 on a simple switch!
fishadventure is offline
post #14 of 20 Old 11-13-2013, 06:39 AM Thread Starter
beakerbload
1987 YJ Wrangler
Yeah I intend to attempt to clean it up this weekend(thurs and fri for me), if it doesn't work, i'll jump it or try to find a replacement. Got a line on one though the wrangler forum in the part out section. He's asking 45 shipped for the rheostat + the tailgate door latch handle. I may do with just the rheostat, I can get a new handle for 10$ shipped total elsewhere.
Thanks for the picture brentd711.
post #15 of 20 Old 11-14-2013, 05:27 PM Thread Starter
beakerbload
1987 YJ Wrangler
Well, pulled off the dash and pulled the rheostat. Gave it a good cleaning. Nothing. So tried to jump the wires, again nothing.
