RFC: Jack Stand Placement - JeepForum.com
post #1 of 7 Old 04-13-2010, 07:45 AM Thread Starter
GreatWhiteMoth
From the perspective of trying to work as safely as possible, where are the best places to put jack stands? Are there different spots when doing different kinds of work? I have been looking at 24" stands, are these safe enough or should I look at something a little lower?
thanks in advance for any comments.
GreatWhiteMoth is offline
post #2 of 7 Old 04-13-2010, 07:50 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
24" stands work great. You can place them just inboard of the spring hangers on the frame for axle work/spring work.
For just general lifting of the rig, I like to go right on the axle tubs in the rear and right under the spring plates in the front.
You can easily put the whole rig in the air using the axles, but I don't like having the whole thing lifted just by the frame inboard of the inner spring hangers. If I do that, I also put a stand under the bumper.
Also, a good jack point is the rear pumpkin and the front axle tube just to the pass side of the pumpkin.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 7 Old 04-13-2010, 07:55 AM
Area.3.Fiftyone
Another thing I do when supporting it under the axles is to leave the wheels and tires on if you can and work on one side at a time.
That way if it does fall, it won't fall all the way to the ground and crush you. It will fall on the tires and give you a chance of surviving.
If I take a wheel and tire off to work on the axle or something, I lay the wheel and tire on the ground under the drum or rotor so that it falls on it instead of all the way to the ground. Try and keep body parts from between what you are working on and the ground.
I also leave my floor jack under the pumpkin or axle tube when up on the jack stands if possible.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #4 of 7 Old 04-13-2010, 08:12 AM Thread Starter
GreatWhiteMoth
Yeah, I am totally down with that whole not getting crushed thing.
So in general, you should do all 4 jack stands only if the specific task requires it?
post #5 of 7 Old 04-13-2010, 08:29 AM
Louie4
Depending on what I'm doing I'll put the jack stands on the frame where Rusty mentioned or if I need a wheel up I'll put it on the axle itself. Putting them on the frame allows the suspension to droop in case you need to do some suspension work. I generally use a minimum 2 jack stands and I'll place a tire(s) behind a wheel(s) as a chalk just for peace of mind. I'll even put one behind a wheel and the other under the jeep just a buffer in case it falls for some reason.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 7 Old 04-13-2010, 08:29 AM
Area.3.Fiftyone
Yes.
Only put the whole rig off the ground if you need to for some reason.
post #7 of 7 Old 04-13-2010, 08:50 AM
rustywrangler
Originally Posted by IronMaiden View Post
Yes.
It has to do more with the wheel base than anything else. Because the jeep is so short, when you put it on 4 stands from the frame it gets wobbly.
An example would be my brothers Tundra. I have no issues putting it on four stands to the frame because it is soldly balanced.
Floor jack / jack stand max. height and weight tuffluv JK Wrangler Technical Forum 1 10-15-2008 12:22 PM
Jack stand location hevybluzer YJ Wrangler Technical Forum 16 12-17-2007 06:51 AM
Jack stand placement DogPak TJ Wrangler Technical Forum 12 08-05-2006 03:13 PM
REBB / jack stand question spinnjase TJ Wrangler Technical Forum 8 07-07-2005 06:20 PM
Placement of floor jack flipper TJ Wrangler Technical Forum 1 02-05-2005 07:42 PM
