Reverse wipers before fluid? *Rage face* - JeepForum.com
post #1 of 3 Old 05-06-2010, 09:56 PM Thread Starter
Fhajad
So, with all the bugs flying around, I'm kind of tired that my wipers do a complete wipe to the other side BEFORE my washer fluid shoots out. Therefore, I have bug guts stuck to the windshield and scrapped across it. And there's no way to get them off.
Is there some way to switch the two around and make it shoot fluid BEFORE the wipers?
I'm thinking the most hardcore way would be to make it a manual switch. I want something a bit less hardcore though.
Fhajad is offline
post #2 of 3 Old 05-07-2010, 06:13 AM
dodger889
Easy to do think about install an other switch to run the washer pump. Two wires and momentary switch needs to be put in the pump circuit. One going to power and one going to the pump.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 3 Old 05-07-2010, 09:26 AM Thread Starter
Fhajad
That's what I was figuring. I'm trying to think of a less hardcore fix to it, but I will if I have to.
Fhajad is offline
Very strange electrical problem, blinkers, sterio, wipers and wiper fluid dont work jeepgunner12 TJ Wrangler Technical Forum 9 12-05-2009 12:18 PM
Reverse was grinding, wouldnt go in gear, now leaking fluid... machine0020 TJ Wrangler Technical Forum 4 07-17-2009 10:32 PM
Question about white face reverse glow gauges... 2002 X TJoshX TJ Wrangler Technical Forum 2 08-20-2007 07:52 AM
windshield wipers and wiper fluid sprayers not functional brianBOFH TJ Wrangler Technical Forum 7 06-13-2007 05:18 PM
washer fluid and wipers aboynamedmoose YJ Wrangler Technical Forum 1 12-04-2002 12:48 PM
