reverse lights won't turn off - Page 2 - JeepForum.com
post #16 of 16 Old 08-17-2011, 05:42 PM Thread Starter
phil1330
1964 CJ5
Think I got the problem solved...Knock on wood!!! The rear wiring harness going to the rear taillights and up through the tub. It had a slight wear on a couple of wires(none hot though). At the same spot in the wiring harness there is a wire connector(I'm thinking thats for a hardtop light or wiper). One of those wires on the connector was hot. So when it was all getting wet I thinking that was sending the hot from the connector to the tailights. It rained inside of it a couple days after I fixed it and the lights did not turn on.
Hope thats it bc I have no idea what to do next if it happens again.
Thanks for the help everybody.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
reverse light switch wires cut/ no reverse lights Floppy YJ Wrangler Technical Forum 9 02-16-2014 01:52 PM
Just installed LED Tail lights but reverse lights come on with brake lights... Yarney05 TJ Wrangler Technical Forum 19 04-22-2011 12:13 PM
turn signals and reverse lights skid6 YJ Wrangler Technical Forum 2 11-23-2010 06:36 AM
Round tail lights with reverse lights built in? AnonymousD YJ Wrangler Technical Forum 4 11-16-2010 11:53 PM
No reverse lights and dash lights bright up barefoot352 TJ Wrangler Technical Forum 2 07-07-2009 09:26 PM
