Reverse light wiring? - JeepForum.com
post #1 of 10 Old 02-03-2013, 07:51 PM Thread Starter
johnt7558
Ok i want to add extra led reverse lights to my yj.
Easy way is to just tap into stock wiring at tail light or have it on another switch byitself.
But what if i want both? How can i wire up extra lights on stock reverse switch AND seperate switch at the same time? The reason i ask is i would like for the new lights to come on in reverse but would also like to be able to
Turn them on while in p psrk .
johnt7558 is offline
post #2 of 10 Old 02-03-2013, 07:57 PM
Xpress
A couple of relays is all you would need to flick them on. One relay flicks them on when you shift into reverse, one relay is switched on and off by a separate switch.
All about that unibody life.
Xpress is offline
post #3 of 10 Old 02-03-2013, 08:00 PM
kloppk
Just use a SPDT toggle switch. SPDT = Single Pole Double Throw
Hook the Common terminal of the switch to the feed to the new LED lights.
Hook one of the other terminals to +12V.
Hook the other terminal to the existing reverse light bulb circuit.
In 1 position the new LED lights will come on when the reverse lights are on.
In the other position the LED lights will be on regardless of the other reverse lights.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #4 of 10 Old 02-03-2013, 08:01 PM Thread Starter
johnt7558
Ive heard i need a diode inline to keep the seperate switch from back feeding through my brake switch. Does this sound right?
post #5 of 10 Old 02-03-2013, 08:11 PM
Soundy
Not with the proper switch wiring, as kloppk describes.
Soundy is offline
post #6 of 10 Old 02-03-2013, 08:17 PM Thread Starter
johnt7558
So where should i tap into existing light wiring?
Between fuse box and stock reverse switch or between stock reverse switch and tail light?
post #7 of 10 Old 02-03-2013, 08:21 PM
Soundy
It would have to be after the reverse switch, otherwise the new lights would be on all the time.
Actually, you could feed one side of the new switch from before the reverse switch (for the "manual" operation) and after it for the "normal" reverse function. Personally, I'd be more inclined to feed the "manual" side from a constant 12V source so they can be turned on without the key on, for use as utility lighting.
Soundy is offline
post #8 of 10 Old 02-03-2013, 08:32 PM Thread Starter
johnt7558
So i can tie in to existing wiring right at tail light for the light to run with brake switch, then run another wire to new light for use with the key in locked position. Will the led not back feed to existing reverse light?
post #9 of 10 Old 02-03-2013, 08:34 PM
Soundy
Okay, look at it this way: when the switch is to the left, the new lights get fed the same power going to the stock lights. When you flip it to the right, the power flows only to the LEDs, but not the stock lights.
You could run the one wire from the stock lights, but if you want the switch in the dash, you'll be running a wire all the way to the front, just to run another back to the light. Be easier to tap it off under the dash, so you only have to run a single wire back to the new lights.
Also, you should put a fuse in the constant lead, for safety.
Here's an updated diagram, should make more sense:
Soundy is offline
post #10 of 10 Old 02-03-2013, 08:47 PM Thread Starter
johnt7558
Got it!!!
Thanks Soundy i was goin about ita totally different way trying to power new light with two different power source instead of powering double throw "switch" with two sources and one wire to new lights! Thats why i love this forum!
