reverse arch YJ rears in D44 front - JeepForum.com
post #1 of 2 Old 06-26-2002, 08:03 PM Thread Starter
Niseep
Okay, so I may get flamed, but I'm in need of help. I have a nissan pathfinder with a D44 from a wagoneer in front and I originally was told that YJ rear springs would hold up the front no problem, well that guy screwed up and there's some major reverse arch in the springs and it's hitting my centerlink. We threw some 2" softride springs on there, and it has about an inch of positive arch and the truck is way up there! About 9.5" over stock (SOA).
So, I'm wondering if anyone can suggest a CJ or YJ spring that maybe wouldn't put the truck up so high as the 2" lift springs (I want it as low as possible for now, I'm running into problems liftin the rear that much). I'm trying to find a set of front YJ springs to see if the extra leaf will help much, so if anyone has a set i'd be interested. Or, can anyone recomend a spring that would sit near perfectly flat, or a spring that I can get away with some slight negative arch and not risk breaking the spring when flexing. Maybe 1.5" lift springs? It's a 3.0L V-6 so it's not going to be as heavy as your guys' 4.0L engines. You all know more than I do so englisten me, please! thanks for all advice.
If worse comes to worse, does anyone have any 2" lift springs (leafs) they could sell me?
Niseep is offline
post #2 of 2 Old 06-26-2002, 08:26 PM
UglySkunk
UglySkunk's Avatar
in bout a month I will have a set of stick front YJ leaf springs for sale cheap since I am lifting my YJ if you are interested let me know
91 YJ currently rebuilding
my jeep can fly can yours
if you don't know about cages or spiked tang sit down and shutup
UglySkunk is offline
Can one re-arch leaf springs? Sambox YJ Wrangler Technical Forum 6 11-17-2009 10:16 AM
lift spring arch????????????? rip_1986 YJ Wrangler Technical Forum 4 03-18-2009 01:54 PM
SOA spring question, no arch Justincredible YJ Wrangler Technical Forum 21 02-09-2009 10:38 PM
Can I reverse RE XD front springs? White347LX YJ Wrangler Technical Forum 7 09-24-2006 08:29 AM
To Re-Arch or Re-Spring...? CanukYJ YJ Wrangler Technical Forum 12 09-25-2003 06:00 PM
