retainer clip for rear brake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > retainer clip for rear brake
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military DiscCurrie Currectlync Steering Upgrade Kits and Currie Anti-R
Unread 02-27-2009, 09:58 PM   #1
kingkong1
I am having an extremely hard time removing this how do you do this?
kingkong1 is offline   Reply With Quote
Unread 02-27-2009, 10:10 PM   #2
Barrio
If im thinking about what your asking for there is a screw driver that has a twist end that pushs the spring and pops the pin.
Ill get you a link.
http://www.thepartsbin.com/cartools/...set-356-d.html
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Unread 02-27-2009, 10:18 PM   #3
obsessedjeeper
is it the clip that holds the pads on? If so, get a pair of needle nose pliers and grab the outside, push it down, twist 90 degrees and pull it off.
Keep on Jeepin
95 YJ
98 ZJ
obsessedjeeper is offline   Reply With Quote
Unread 02-27-2009, 10:28 PM   #4
kingkong1
no its for the rear brake extension for the rc 4' lift. are the any tools i can use other that special tool you recommended
Unread 02-27-2009, 10:29 PM   #5
Barrio
Flat head screw driver, dikes, hammer....anything really.
www.pgh-offroad.com
Unread 02-27-2009, 11:03 PM   #6
sailmike83
i ended up tapping the lip with a hammer and a flat head screw driver
sailmike83 is offline   Reply With Quote
