Restrictor Removed? - JeepForum.com
post #1 of 6 Old 12-13-2001, 06:25 PM Thread Starter
trekquest
Restrictor Removed?
What is this restrictor that everyone is talkin about? What does it do?
Thanks, Dave
trekquest is offline
post #2 of 6 Old 12-13-2001, 06:38 PM
Atropine
Atropine's Avatar
It is a little plastic thing that looks like a crescent moon. Its on the inside of your intake pipe. I'm not sure why its there, some people see a power increase some don't.
here is the post from jedi
http://www.concentric.net/~jman/jeepmods.html
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 6 Old 12-14-2001, 12:48 AM
jeffy
jeffy's Avatar
It creates a venturi effect. What it does is speeds up the air flow to cause a vacuum in the Evap Canister and Crank vent. So it draws out the fumes re-enter the engine.
I saw no difference with it in or out. I've got a custom air tube so it's not in there anymore anyway.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 6 Old 12-14-2001, 05:58 AM Thread Starter
trekquest
Thanks for the info, I'll see how it works. Dave
post #5 of 6 Old 12-21-2001, 07:56 AM
MKB
I've tried this, and I must say: I didn't notice any difference. No change in gass milage, no power increase. I've droped in a turbo tube now, and you can definatly notice the difference.
94 YJ 2.5, 5 spd
PerformanceAid Throttle Spacer
K&N w/ Turbo Tube
Swaybar Disco's
2.5" Spring Lift w/1.25" HD Shackle
1" Body Lift
4.56 gears w/ Rear Detroit Gearless
31x10.5 Nankang Radial A/T
15 to 20 Gal tank conversion
Warn 9000LBS
Dual Batt and 150 Amp Alt
Home-made Front&Read bumpers
Hard & Soft tops
MKB is offline
post #6 of 6 Old 12-21-2001, 04:23 PM
Kev
Master of the Obvious
Kev's Avatar
MKB, what do you think about the highly-debated Poweraid TBS?
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
TJ air restrictor? Brack TJ Wrangler Technical Forum 6 12-11-2004 06:13 PM
Air restrictor 91yjeeper YJ Wrangler Technical Forum 7 02-19-2004 03:16 PM
air restrictor YoungJeeper YJ Wrangler Technical Forum 3 12-17-2003 10:31 PM
air restrictor hxc777 YJ Wrangler Technical Forum 2 05-03-2003 05:53 PM
Air Restrictor?? Where is it? Mike611 TJ Wrangler Technical Forum 0 02-16-2002 07:23 PM
