Resto - JeepForum.com
post #1 of 5 Old 03-11-2011, 07:08 AM Thread Starter
Flanagan69
Resto
I am planning on doing a tub off restoration on my 93 this summer, planning on new paint, powder coating the chassis, and mainly cleaning up the mess of wires under the hood. Any heads up before I start and suggestions would be awesome.
Flanagan69 is offline
post #2 of 5 Old 03-11-2011, 01:01 PM
firefighter315
Welcome to JF! I'd say just for starters, begin soaking the body mount bolts in some PB Blaster several weeks before you start. Drill a tiny hold (big enough for the straw) above each captive nut and soak the crap outta them. I am in the middle of a tub off right now and did this with absolutely no problem when it came time to remove the bolts. Tons of info on here, search tub off resto and see what ya get. Good Luck and post up a lot of pics!!
My YJ Build Thread
firefighter315 is offline
post #3 of 5 Old 03-11-2011, 01:26 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Invest in PB Blaster, Anti-seize, POR-15 and associated products, and beer.
I did this, and can tell you it's worth it.
The roll cage bolts made me drink. Get decent tools, grinders, impacts etc.
Also see the YJ build page for lots of other restorations.
Welcome to Jeep Forum. My build is attached in the link below and it is very similar to what you are planning.
Best of Luck,
Chet
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #4 of 5 Old 03-11-2011, 01:35 PM
giggityjeeper
Best of Luck,
Chet
LOTS AND LOTS of those beers, the tear down will be the most frustrating, figure on breaking lots of bolts and things..... and lots of gringding and crap to get it nice to be powerdercoated....
ALSO powerdercoating takes lots of heat, so you axles and stuff will need broken down and all the gears, fluid, rubber seals will need to come out prior to coating and all redone with new ones.... nota fun job either...
the end result will be nice Im sure... good luck
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #5 of 5 Old 03-11-2011, 01:52 PM
hotelconucc93
2010 YJ Wrangler
I chose the POR-15 over the powder coat for one reason. Money.
