Restart Idle High and High Oil Pressure - JeepForum.com
post #1 of 3 Old 12-09-2008, 08:36 PM Thread Starter
bringbackphish
Hey im new here and have a couple of problems, Just picked up my Yj a couple weeks ago its also my first stick shift. When I stall occasionally and restart, the idle is way too high around 2200 rpm and stays there for about 20 seconds. Also my oil pressure gauge is reading off the meter but it does go down when the engine is off. Any ideas. Thanks,
Rob
bringbackphish is offline
post #2 of 3 Old 12-09-2008, 09:11 PM
bigredcherokee
Rob you could have a bad sending unit or gauge. Do a search on the forum and it will bring up a tone of info. As for you idle I beilieve your carbarated and could have a sticking coke or vacume leak not sure. One delt with a carb on my 90 long time ago and I pulled it off and went MPI.
For those of you in Louisiana visit
bigredcherokee is offline
post #3 of 3 Old 12-09-2008, 09:46 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Umm, he has TBI, it's a 4-banger.
2.5L I4 TBI (fuel injected) - 121 hp @ 5000 rpm, 135 ftlb @ 3500 rpm - used in '87-'90
It's not uncommon to see the oil pressure rise (my 4.0L pegs the gauge at idle when cold) at a really high idle, although I doubt the accuracy of the gauge due to the afore-mentioned sender unit's reputation. Replace it if you feel the need to, FWIW I haven't replaced mine yet...
As for the high idle on start up, start with checking for the vacuum leaks that bigredcherokee mentioned, and then thoroughly clean your throttle housing & idle control motor.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Low Idle Cold, High Idle Warm Lon33 YJ Wrangler Technical Forum 13 10-29-2014 10:24 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 08:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 11:19 AM
High oil pressure at idle???? wml52 TJ Wrangler Technical Forum 4 01-11-2007 09:30 AM
High Oil pressure reading at idle semper fi YJ Wrangler Technical Forum 4 03-20-2002 03:55 PM
