#61 | |
what do you think about a body drop to lower the center of gravity on a YJ and section the fenders up and put on tube fenders??? pros and cons would be nice?
#62 |
would like to have posi or lockers in the rear before it really starts getting to be offroad season. What do I need? what's an easy crossover?
#63 |
writeup for how to install a holly fuel pressure regulator for my yj 4.2. Think I got an idea, but would like info from someone who has done it.
#64 |
I need a GOOD diagram (with pics?) Of the stock vacuum hose layout. Where each hose starts and where it goes. I'm pretty sure mine are all jacked from the previous owners and want to make sure I have them all figured out before I start tinkering with other things on the engine. I have an 89 4.2 YJ with the craptastic Pugot (sp?) 5 speed. Thanks guys and gals.
#65 |
Suspension Shakles
I need a little more ground clearance to hold my own in my local club who mostly run Landover / range rover. First event I entered was a blast but I grounded out several times
Gallery : Yorkshire Off Road Club, Land Rover and off road club Not wanting to spend too much cash (aka im skint after replacing the leaf springs and buying a set of 31x10 silverstone extremes to cope with Yorkshire mud) I am planning on experimenting with some home made shackles, does anyone have some suggestions on plate thickness and lengths I can run on standard drive train componets. I was contemplating using 1/4" x 2" bar and adding an extra 2" length on the standard shackle with a bracer piece welded in between for rigidity ? Thoughts pls ) |
#66 |
Got my first soft top, now just need a few directions, tips, for taking it down. I don't have a manual so any help would be much appreciated. Sure it's not difficult just don't wanna break it!
Thanks |
#67 |
Junior Member
Easiest way to find a 4cyl YJ that is being parted out, all 4 cyl came with 4.11, so unbolt axles, and install new axles
#68 |
Junior Member
YJ Full Door windows
Has anyone found a way to remove the vent post and vent windows and replace the window and vent with a solid window like the one used in a TJ?
#69 |
scallywag
not the 4cyl autos. they came with 3.73's
_______________________ Capt. Nate aka Scallywag _______________________ 95 yj 4.3 vortec csfi, 4l60e/np231cj 2007 Lincoln MKX 3.5l 2011 F150 4x4 5.0 supercrew _______________________ |
#70 | |
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig) |
#71 |
what about a write up about swapping out the tf-999 auto and putting in an ax-5 in a yj with a 2.5. start to finish and everything involved
#72 |
Junior Member
auto to manual swap
The swap from an automatic to stick is quite easy, I have done it bolth ways, from manual to auto and auto to manual.
If you want more info let me know Bill |
#73 |
Dizzy replacement/upgrades and timing adjustment instructions with pics on 4.2 would be helpful to this guy.
#74 |
Swing out tire carrier/bumper plans would be nice. I have seen some nice ones on here, but it seems like no one lists the pieces, sizes, or cuts they made. THANKS!
#75 |
easy to install rocklights for a yj
1994 YJ RED JEEP CLUB MEMBER #567 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
