Request write-ups on repairs & modifications here - Page 22 - JeepForum.com
post #316 of 334 Old 07-02-2013, 06:18 PM
roadyrob
1987 YJ Wrangler
[QUOTE=Firefyter-Emt;15208711]Has anyone come up with a nice way to modify the windshield bars to be a quick disconnect to remove the whole bar? I want to keep them in the Jeep, but make they removable quickly in order to drop the windshield. I was thinking along the lines of something that uses quick release ball bearing pins.[/QUOTE
heres xpress's build thread
http://www.jeepforum.com/forum/f12/a...hread-1503048/
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #317 of 334 Old 01-14-2014, 03:10 PM
Cuesoccer24
has there been a write up of how to remove and replace the nutserts that hold the bolts which go into the frame for a transfer case lowering kit?
Cuesoccer24 is offline
post #318 of 334 Old 01-20-2014, 06:59 PM
Louie4
See if this helps.
Nutsert Replacement
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #319 of 334 Old 01-20-2014, 09:00 PM
Cuesoccer24
Yes it does thank you
post #320 of 334 Old 02-14-2014, 03:19 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I was looking for basic info and decided to check the faq first, but the entire transmission section is all manual transmissions, except a note about 32rh replacing tf999.
just sayin :O
-April '14- YJoTM- June '15
The_Goob is offline
post #321 of 334 Old 02-16-2014, 05:37 PM
Soldierfoley
I just ran all new vacuum lines to my 4wd switch, but I'm not sure of the direction of the check valve on the yellow/white hose. Does anyone know off hand?
Soldierfoley is offline
post #322 of 334 Old 05-03-2014, 12:25 PM
rbat
1990 timing chain 4.2
It would great to have a write up about the timing chain replacement issues regarding the damage to the inside of the cover, cam bolts, chain snubbers/guides etc.
rbat is offline
post #323 of 334 Old 05-03-2014, 01:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Hey guys, I have every intention if putting most of these writeups in a FAQ I'm just not as organized yet.
Luck Favours The Prepared
Anticanman is offline
post #324 of 334 Old 05-03-2014, 02:50 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Is rustywrangler ever coming back around? I had submitted a writeup since he asked for an exhaust writeup.
The_Goob is offline
post #325 of 334 Old 05-03-2014, 02:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
He pops in from time to time. I could really use a volunteer to organize this though.
post #326 of 334 Old 05-03-2014, 02:58 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
So do you just need someone to maintain a new FAQ listing, and maintain new submissions and stuff? I could probably handle that
The_Goob is offline
post #327 of 334 Old 05-03-2014, 03:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Basically to compile writeups as in this forum and get them ready to be published to one of the stickies like jbolty's list.
post #328 of 334 Old 08-10-2014, 04:57 PM
hardluk
1987 YJ Wrangler
I was wondering if someone could fix the links for the 4.0 swap in the FAQ.
hardluk is offline
post #329 of 334 Old 11-18-2014, 07:20 PM
bharris68
Daily Driver
Hey there - could we link to this one above/below the LED Dash write up?
http://www.jeepforum.com/forum/f12/r...er-how-991307/
Yes - I know it's mine. I could use the gallery space I have now as a lifetime member to put the pictures in and then we won't lose them - would that be helpful?
bharris68 is offline
post #330 of 334 Old 04-27-2015, 12:15 PM
Que89YJ
Anticanman, putting together a list with my bookmarked threads would probably go a long way in making a more complete list. I have a ton of bookmarked threads and I know others do too. If you want to put together a more complete list PM me and I will at least start to make something a little more useful.
Que89YJ is offline
My FLAT skid, write up by request, RnEmOvr TJ Wrangler Technical Forum 43 02-14-2015 04:47 PM
How much for repairs Bionix YJ Wrangler Technical Forum 27 07-29-2011 07:50 PM
clutch replacement write up request Rocky_Cosmark YJ Wrangler Technical Forum 2 12-28-2009 07:31 PM
a few repairs nblax TJ Wrangler Technical Forum 0 07-07-2004 08:10 PM
YJ repairs shookwell YJ Wrangler Technical Forum 8 02-21-2003 04:17 PM
