Request write-ups on repairs & modifications here - Page 11 - JeepForum.com
post #151 of 334 Old 01-16-2011, 05:24 PM
brockmarzullo
Originally Posted by tript1125 View Post
Can you flip the leaf springs to raise a YJ
No. You can go Spring Over Axle (SOA) but it is a lot of time, work, fabrication, and cash to do so.
brockmarzullo is offline
post #152 of 334 Old 01-17-2011, 11:08 PM
Jonny92yj
Request write up for hood lights/hi lift mount please
Hey all im looking for a good write up and pic on how to make my hood rack for a hi lift and to mount some lights on. Thanks
Jonny92yj is offline
post #153 of 334 Old 01-18-2011, 08:42 PM
McFatter
Anyone have a DIT tube fender install write up using the factory inners?
im working on building my own but I dont have a write up on them. I will look and see if I have took many good pictures so far and if so I will make a write up
McFatter is offline
post #154 of 334 Old 01-24-2011, 09:38 AM
tejasjeepgirl
I'd like to know if there is a way to get the Check Engine Light to reset for good. Mine keeps saying I need a Code 33 (A/C Relay) and that's not true. I know it's an issue with YJ's, but I can't figure out how to get rid of this. It's been reset with the reader at the mechanics. I've disconnected the battery as well. It just keeps coming on. What's weird is that you can drive it about 100 yards, cut it off and then the light goes away. If it's under 60 degree's outside (which doesn't happen much in Texas) then it won't come on at all. Go figure. If anyone has a solution, it would be great to write it up.
tejasjeepgirl is offline
post #155 of 334 Old 01-24-2011, 06:54 PM
dwdrums40385
i would really like to see a writeup on how to replace a clutch/pilot/throwout/slave cylinder on a AX-5 internal slave system, it would make life a lot easier, i looked but could not find one. if there is one please let me know. i see the internal to external slave swap, but thats not what i'me looking for.
dwdrums40385 is offline
post #156 of 334 Old 01-27-2011, 11:05 AM
Rocky_Cosmark
Me too I have the Haynes manual but its not the most extensive with this. A write up would be very helpful
Rocky_Cosmark is offline
post #157 of 334 Old 02-07-2011, 12:57 PM
jeephelpneeded
I have unexpectedly gotten a 91 Wrangler from my father in law and want to make it bad a$$. Do you need to replace the stock control arms for rough country 4in. lift and 33-35in. tires? I will also be getting the SYE CV drive shaft kit. Please I need someone knowledeable, I have been unable to get a definitive answer thus far.
Thanks!
jeephelpneeded is offline
post #158 of 334 Old 02-07-2011, 01:03 PM
sbsg2005
a 91 wrangler dont have control arms it has leaf springs and you do have to replace them
sbsg2005 is offline
post #159 of 334 Old 02-07-2011, 02:18 PM
jeephelpneeded
This is what I am being told by my father who has limited experience with lifts. I am wondering if it is the truth.
"you will destroy this truck with that kind of lift and no experience. new control arms would
be must. even if alignment could be achieved the suspension would only work going
up maybe. going down it would bind, twist, then break. the larger the tire the lower you effectively
change the gear ratio for off road this means wearing a clutch out for an automatic it
means death"
post #160 of 334 Old 02-07-2011, 03:46 PM
monsterenergy
means death"
theres no controll arms on yjs just leafs so you cant change them and with a lift it depends on how much your lifting and what you need for it. i bought a 2" and i just have to bolt it on nothing else to do (maybe a drop piman arm and extend the brake lines but i will know when i bolt it on. 4" is more work and money and soa is alot of time money and requires some fab skills. you dont have to change the gear ratio but you will have to to run 35s because you can run stock gerars with 33s but its terrible 31s would be best and dont look bad on a 4" lift on a yj
1994 YJ
RED JEEP CLUB MEMBER #567
monsterenergy is offline
post #161 of 334 Old 02-07-2011, 07:01 PM
jeephelpneeded
How hard is it to change the gear ratio? how much money does it cost? Does anyone know if that has a write up on it?
Thanks for the info.!
post #162 of 334 Old 02-10-2011, 07:21 AM
Soldierfoley
Has anyone hardwired their FACTORY gauge cluster? I'm trying to pinpoint the reason my temp sensor and gas gauge don't work properly. I think getting ri of that 1980's circuit board behind the cluster would simplify the process. Any advice for or against this idea will be appreciated.
Soldierfoley is offline
post #163 of 334 Old 02-10-2011, 01:02 PM
GEARHED
I'm working on the same thing right now but all gauges work. Its the wonked out after market toggles that have the wiring messed up to the fuse box (yes, I'm still going to use that because fuses are easier to replace). The temp sensor and gas gauge issues usually come from them not being grounded properly or frayed ends with no covers on one or both ends. Check to see if they were crimp covered or bare wire, strip and put new crimps on then follow back to the box then out to the dash cluster to start. Haven't dug into mine enough yet to give a better answer.
Old enough to know better, still young enough to do it.
1994 YJ to give the 89' company.
GEARHED is offline
post #164 of 334 Old 02-13-2011, 05:11 PM
natedawg3256
Question About tie rod ends and bushings
Looking to replace all the tie rod ends and front bushings. Or would i need to beef up I have a 3 in bds lift . Any suggestions. Level of diffulicty
natedawg3256 is offline
post #165 of 334 Old 02-14-2011, 10:20 AM
94yjay
I just replaced the entire unit with aftermarket gauges
94yjay is offline
My FLAT skid, write up by request, RnEmOvr TJ Wrangler Technical Forum 43 02-14-2015 04:47 PM
How much for repairs Bionix YJ Wrangler Technical Forum 27 07-29-2011 07:50 PM
clutch replacement write up request Rocky_Cosmark YJ Wrangler Technical Forum 2 12-28-2009 07:31 PM
a few repairs nblax TJ Wrangler Technical Forum 0 07-07-2004 08:10 PM
YJ repairs shookwell YJ Wrangler Technical Forum 8 02-21-2003 04:17 PM
