Replacing Windshield Pitfalls- advice? - JeepForum.com
post #1 of 9 Old 03-31-2007, 10:55 PM Thread Starter
keithgamble
i'm about to undertake replacing my windshield. I have the rubber seal off the jeep I took this from. I'd like to know if anyone has any suggestions on this effort. what should I be looking out for or expect. I know this is broad topic but I get that feeling I'll take off my old one and find out that when you pull it off all hell breaks loose (or simply I break the linkage on my wipers). I'm not "the man" around the garage so any advice is appreciated.
Keith Gamble
Morgantown, WV
95 Wrangler 4.0 L
keithgamble is offline
post #2 of 9 Old 03-31-2007, 11:16 PM
Burnerman
Burnerman's Avatar
I believe they are "glued" in. They don't use the old fashioned rubber gasket, they just look like they do. They use ureathane glue to hold them in. I'm having my neighbor, that works for an autoglass co, pull my windshield out this summer so I can clean up the surface rust under the reveal moulding and then put it back in so it doesn't leak anymore.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 9 Old 04-01-2007, 05:45 AM
sgtcherokee
they are glued in, I just replaced mine the other day , It went pretty straight forward . there are two rubber gaskets , an outer that goes around the edge of the glass and the inner that covers up the pinch weld. My frame was tweaked badly do to a roll over so I ended up not putting the inner seal back on .
You will need to goto a parts store and buy a tube of winshield adhesive I got the 3M brand that you use in a caulk gun. Run a fairly thick bead around the frame on the outer side of the pinch weld and then put the outer seal around the glass , then you just need to place the glass in the frame and make sure it's seated all the way around. I had trouble with mine only because the frame was not straight , but it's in and doesn't leak.
good luck !
94 YJ , comp cut , 8.8 , 102" WB , XJ rear springs , and a few other things here and there
sgtcherokee is offline
post #4 of 9 Old 04-02-2007, 11:59 AM Thread Starter
keithgamble
I must not have been clear, i'm actually not replacing the glass, just the frame on my jeep...the glass is actually in the frame I bought. Nontheless, thanks for the advice I did not know the glass was glued in there. the gasket I was talking about goes b/w the winshield frame and the body near the fire wall.
Keith Gamble
Morgantown, WV
95 Wrangler 4.0 L
post #5 of 9 Old 04-02-2007, 01:11 PM
jonnyri
jonnyri's Avatar
The hinge seal right?... get a new one - around $25. They just lay in and are sandwiched between the windshield and shroud. dirt and muck build up on it pretty easy and often is the cause of water leaking in... and in most cases dumping out on your gas pedal foot. Windshield just folds down and seal goes in between.
Dirty, rusty, banged up YJ.
OSJ / NEA Delegate
jonnyri is offline
post #6 of 9 Old 04-02-2007, 02:08 PM
Axl Jack
Did you already remove those torx bolts that held your old frame in? If all of yours came out, consider yourself lucky. I had to drill mine out.
TORX SUX
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #7 of 9 Old 04-02-2007, 03:42 PM
ovrlnd
it is a pretty easy deal. the torx on the windshield frame came out it will be straight forward. when you remove your old windshield the vin# plate will be riveted to the windshield frame, drill the heads off the rivets and transfer it to the new frame. if you are having to pull out the wiper linkage assembly from the old frame, always in my case they always come out easier but getting them back in can be tricky sometiimes, nothing major, just be patient. I would also like previously mentioned clean the dirt and junk from the seal and replace with new, you won't regret it. if you don't fold your windshield down that often address any rust on the tub in that location since you are already there.
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline
post #8 of 9 Old 04-12-2007, 11:03 PM
nudosimmons
how much do new windshields cost?
1988 xj 4.0, ba-10, np231
trimmed fenders
3in lift, 33s
herculinded interior
custom bumper
nudosimmons is offline
post #9 of 9 Old 04-12-2007, 11:25 PM
Semperfi
i had mine replace for $150... done in less than an hour
"Once a Marine...Always a Marine"
Semperfi is offline
Advice needed regarding "32s." Pitfalls? AuburnTiger92 TJ Wrangler Technical Forum 45 12-15-2009 02:58 AM
replacing windshield shea666 TJ Wrangler Technical Forum 2 04-21-2009 09:50 PM
Replacing windshield glass mrobertson YJ Wrangler Technical Forum 10 11-13-2006 03:08 PM
Replacing windshield chief1138 YJ Wrangler Technical Forum 9 04-30-2006 11:59 AM
windshield glass needs replacing 93YJfalcon YJ Wrangler Technical Forum 1 03-04-2006 05:15 PM
