Replacing the vacuum motor with an electric one? - JeepForum.com
post #1 of 16 Old 12-31-2012, 06:12 PM Thread Starter
msprooch
I am very comfortable with electronics and was going to do the posi-lock mod when I put in my auto locker but I was wondering just how the vacuum motor worked in combination with the shift fork? And how it physically moved the fork? I would like to make a "electronic posi-lock" and was wanting to toss the idea out to you guys who are more experienced then I am.
Thanks!
msprooch is offline
post #2 of 16 Old 12-31-2012, 06:19 PM
jbolty
jbolty's Avatar
The vacuum motor just slides the shift fork from side to side. I would not be too hard to rig up a solinoid, if you had the parts. But, getting rid of the whole thing and putting in a TJ or XJ solid shaft is a lot easier.
jbolty is offline
post #3 of 16 Old 12-31-2012, 07:15 PM Thread Starter
msprooch
I agree but I want to retain control of locking my shafts for turning radius and if I drive with 4wd in the snow.
So does the shaft slide itself with the fork attached to the shaft?
msprooch is offline
post #4 of 16 Old 12-31-2012, 07:23 PM
jbolty
jbolty's Avatar
http://www.jeepforum.com/forum/f12/c...works-1349980/
jbolty is offline
post #5 of 16 Old 12-31-2012, 07:57 PM Thread Starter
msprooch
I see now that the shaft moves and the fork stays stationary on the shaft.
msprooch is offline
post #6 of 16 Old 12-31-2012, 08:54 PM
NonRubicon
I have also considered doing a electronic posi-lok. It would require a solenoid with the correct throw to match the range of movement of the shift fork. From there, if you were to place the solenoid directly on the axle housing to actuate the shift fork, the solenoid and all electrical connections would need to be completely waterproof. Another option would to have a cable combined with a remote solenoid, kind of like what OX offers for their cable based lockers.
To start on this, you'll need to know the throw distance of the shift fork and find a solenoid that matches that. From there it's just a matter of figuring out how to transfer the solenoid action to the shift fork.
NonRubicon is offline
post #7 of 16 Old 12-31-2012, 09:23 PM
ROWA
ROWA's Avatar
You could try something like this from McMaster-Carr.
http://www.mcmaster.com/#electric-ac...e6u:2thumbsup:
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #8 of 16 Old 12-31-2012, 09:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just lock it over...
Luck Favours The Prepared
Anticanman is offline
post #9 of 16 Old 12-31-2012, 10:41 PM
Old4X
1990 CJ7
http://www.a1electric.com/catalog/cat_trunk.htm
Hmmmm..... I might just find something here that will do it. I already have an electro/vac setup All electric appeals to me as well.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #10 of 16 Old 01-01-2013, 07:20 AM
90DesertTanYJ
Those are interesting, it has my wheels turning. GM uses an electric hydraulic plunger where oil in a cylinder is heated expands and a rod is forced out. OEM replacements are pretty expensive but one from a JY or if you could get a similar style actuator maybe something would work. The GM actuators arent the best and I am thinking between it and the Jeep style, PosiLok came into being!
90DesertTanYJ is offline
post #11 of 16 Old 01-01-2013, 08:38 AM
JohnRodriguez
I had used a diesel fuel shut off solenoid from a CAT 3208 motor to move the fork. I'll try and post some pick of it this evening when I get off work
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #12 of 16 Old 01-01-2013, 07:55 PM
JohnRodriguez
post #13 of 16 Old 01-01-2013, 08:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Is there a lot of give with the electric actuator or is it just a lot of torque? I would think without some freeplay, the splines would chip or the fork would crack when trying to line up the splines
post #14 of 16 Old 01-01-2013, 09:22 PM
JohnRodriguez
what I don't show in the pictures is that inside of the boot is a spring to keep the fork in the free wheel side of the axle sleeve when their is not power to the solenoid.. Solenoids are not a high torque electrical component and you can burn them out if they don't have movement in the axle shaft to get the sleeve to move over freely. I burned out the first one I had made when I actuated it without the jeep in motion.
post #15 of 16 Old 01-01-2013, 09:36 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Good to know.
