Replacing turn signal in steering column - JeepForum.com
post #1 of 9 Old 09-10-2009, 09:57 AM Thread Starter
kilapapipa
Anybody have some quick notes on removing the steering wheel and replacing the turn signal mechanism? I have the part but can't seem to get started. Do I pry the horn off to get to the bolt?
kilapapipa is offline
post #2 of 9 Old 09-10-2009, 10:52 AM
Louie4
"You pass butter"
Louie4's Avatar
Yep, you can just pry that rubber cover over the center off to get to the nut. I believe its a 3/4" nylon locking nut. You'll have to get a steering wheel puller or get creative after that though. Once you get the steering wheel off it shouldn't be too hard to replace the turn signal cam.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 9 Old 09-10-2009, 11:04 AM
lclark2074
what is oppsions on the steering wheel? power, tilt, auto,?
after you get the wheel off theres a dust cover that neads a special tool too.
night crew 226
lclark2074 is offline
post #4 of 9 Old 09-10-2009, 11:11 AM Thread Starter
kilapapipa
It does have tilt and it is an auto. I have a steering wheel puller and I figured I would have to remove some plastic. Where is the special tool used.
Thanks,
post #5 of 9 Old 09-10-2009, 11:24 AM
kloppk
It's for pushing and holding down the spring plate down so you can remove the big "C" clip that holds it on the steering shaft. There is a stout spring pushing it against the "C" clip.
I usually make my own tool out of some scrap steel and a couple of bolts.
kloppk is offline
post #6 of 9 Old 09-10-2009, 11:32 AM
pushead
You need a pressure plate tool. I just did this last week on my jeep. You can get the snap ring out without it but you damn sure wont get it back on.
$15 at NAPA.
Its not a jeep if it dont have 4wd.
pushead is offline
post #7 of 9 Old 09-10-2009, 12:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
$15 at NAPA.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 9 Old 09-10-2009, 12:47 PM
Ron83CJ
I picked up a new turnsignal/windshield wiper control arm yesterday. Ours snapped off, I am assuming I need to follow these instructions. Any hints on how to get the broken piece out? Is tap and die the best or a small drill?
My imageshack with all my Photo's
Ron83CJ is offline
post #9 of 9 Old 09-10-2009, 12:53 PM Thread Starter
kilapapipa
OUTSTANDING, Pics and all, you guys are great.
Thanks
Replacing Turn Signal Switch... compatibility? SHJeeper YJ Wrangler Technical Forum 2 10-03-2009 10:35 AM
Help Replacing Turn Signal Lever - 94 YJ lndwarrior YJ Wrangler Technical Forum 1 03-22-2009 05:43 PM
Turn Signal/Wiper lever broke off in column bamato YJ Wrangler Technical Forum 9 11-04-2008 08:00 PM
locating fingers on steering column not hitting turn signal switch - not resetting dhausman TJ Wrangler Technical Forum 5 06-30-2008 12:17 PM
Turn signal switch on column... 94YJ_FL YJ Wrangler Technical Forum 2 03-27-2004 08:45 PM
