replacing spider gears in D35 - Page 2 - JeepForum.com
post #16 of 19 Old 12-05-2011, 04:23 PM
little_Jeep
Originally Posted by hester88 View Post
If my idea is possible and i would be able to swap the carriers when i decide to go off roading i think i would be ok with the welded gears. I wouldnt be driving everyday on them and my trails arent far from my house so i wouldnt be on the road very much with them. When we arent planning a trail/mud run i can just put the regular carrier back in for more road driving. Thats if this would even work. So as far as the shaft randomly breaking cuz of the weld it would be at slower speeds so if happens hopefully wouldnt cause a whole lot of damage.
Basically, forgetting the entire discussion about is it wise to lock a D35, if you do what you are talking about, you will have two different R&P setups.... neither of them would be the correct setup and backlash, so I susect the end result will be you will have a D35 with a very short life span and the only question will be when & where will it explode.
little_Jeep is offline
post #17 of 19 Old 12-05-2011, 04:50 PM Thread Starter
hester88
that was what i was afraid of. Oh well. it was a cheap idea for better performance. lol.
hester88 is offline
post #18 of 19 Old 12-05-2011, 04:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just buy a mini spool and blow up the R&P already.
Luck Favours The Prepared
Anticanman is offline
post #19 of 19 Old 12-05-2011, 05:27 PM Thread Starter
hester88
cant find one for the d35.
hester88 is offline
axle , spider gears , welding
Help w/ replacing spider gears - Dana 35 Brent99 YJ Wrangler Technical Forum 11 09-17-2010 10:50 AM
Replacing spider gears... Can I upgrade to trac-lock? SolidBrass TJ Wrangler Technical Forum 6 09-06-2010 08:58 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Replacing spider gears? redrockyj TJ Wrangler Technical Forum 6 06-04-2006 07:00 PM
