Replacing slave cylinder - Page 2 - JeepForum.com
post #16 of 30 Old 03-30-2010, 07:22 PM Thread Starter
Roadyy
I haven't put any in it. I checked to make sure it was full but have not changed it. The jeep has 138,000 miles on it. I'm going into this blind hoping to find a lite to follow. lol
Roadyy is offline
post #17 of 30 Old 03-30-2010, 07:27 PM
Burnerman
Burnerman's Avatar
Drain it and put in 10w-30 motor oil. See if that helps. Also drain the old fluid into a clean container. Look for brass in the oil. Your syncros maybe on the way out. Do the fluid change before spending any $$ on the master/slave. It may cure your problem.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #18 of 30 Old 03-30-2010, 07:32 PM Thread Starter
Roadyy
Thanks for the heads up I will bring some home tomorrow and do the oil change and post an update. Thanks again.
Roadyy is offline
post #19 of 30 Old 03-31-2010, 09:20 AM Thread Starter
Roadyy
Ok so I'm going to flush my tranny out tomorrow nite and replace with 10w30 oil to see if thats the problem. I have been checking prices on prefilled m/c s/c combo and found quadretec has it for 160.00+26.00 ground shipping. I can get one from dodge dealer for 197.00 next day. Is the quadratec a better quality for 10 bucks less if that is the next step? Which I truly believe it will be. I talked to the po and he said the mech that installed it would not warranty the installation as he no longer owns the jeep.
Roadyy is offline
post #20 of 30 Old 03-31-2010, 09:43 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Try DORMAN Part # CC649002 for $106.49 at RockAuto Auto Parts for a replacement.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #21 of 30 Old 03-31-2010, 09:51 AM
CountryStyle
I put in the quadatech one a few months ago, was a nice unit, $160 and I dont pay shipping (20 miles from their warehouse). Good luck with it!
CountryStyle is offline
post #22 of 30 Old 03-31-2010, 11:41 AM Thread Starter
Roadyy
I have noticed from other posts that Mean Max gives pretty solid advice and the price is awesome.
Thanks Mean Max. I really appreciate the advice.
Roadyy is offline
post #23 of 30 Old 03-31-2010, 12:17 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks for the kudos.
I just do what I can.
Max
Mean Max is offline
post #24 of 30 Old 03-31-2010, 01:29 PM Thread Starter
Roadyy
I try to give it where its deserved and I have read enough threads and seen the trust others put in your advise.
Roadyy is offline
post #25 of 30 Old 03-31-2010, 07:41 PM Thread Starter
Roadyy
Ok I got to thinking, while waiting on my daughter to get out of her teen small group at church, how much oil will it take to fill the tranny when I flush and replace and how do I get the oil in there. I couldn't think of a way to get it past the tc skid plate to the fill hole. IDK. It's not like gear oil bottle with a hose so hmmm. I know one of you can tell me and so I can realize my idiocy,lol
Roadyy is offline
post #26 of 30 Old 03-31-2010, 07:50 PM
Burnerman
Burnerman's Avatar
I used Mean Max's trick/ technique. Remove the shifter boot or whole tin trans cover with the boot and all if you have no carpet, remove the shifter from the trans with the 1/4 push down and twist. Then aftre you drain the old fluid replace the drain plug, remove the fill plug and then pour the 10w-30 right in thru the shifter hole. Stop when it starts to run out of the fill plug. I bought a 5 qt jug of Walmart super tech stuff. It takes just over 3qt's IIRC..
96 ZJ.
post #27 of 30 Old 03-31-2010, 08:11 PM Thread Starter
Roadyy
Ok so I should buy 1 5 qt jug and another single qt bottle since it is a good idea to flush it with new oil then drain again then put the oil in to stay correct? I just wanna make sure it'sd done rite the first time if this is the culpret. Hope you understand the multiple questions.
Roadyy is offline
post #28 of 30 Old 03-31-2010, 08:29 PM
Burnerman
Burnerman's Avatar
It's fine. Sure I'd fill it up then take it for a short ride then dump it and refill. Try to drain that old fluid when the trans is warm. the short ride with the new 10-30 will help get the rest out. The final fill should have you set. just the short 10 mi ride I took my Jeep on today and the trans shifts smooth. I dumped out gear oil before the fill. I'll probably run it a few weeks and dump it again. 138,000 and it's probably the stuff that it left the factory with in 92. Oh the drain plug is magnetic. Be sure and clean the ball of grey metal dust off of it before you reinstall it.
96 ZJ.
post #29 of 30 Old 04-01-2010, 05:09 AM Thread Starter
Roadyy
Thanks burnerman. I will post my results here when I get-r-did.
Roadyy is offline
post #30 of 30 Old 04-03-2010, 11:50 AM Thread Starter
Roadyy
Ok this is a bummer. I flushed the tranny with 10w30 oil and its still doing the samething, but it's doesn't seem to be as bad as before. I am gonna order the m/c-s/c prefilled from rockauto and replace the aftermarket junk thats in there now. If this doesn't cure what's ailling us, looks like I'll be doing an extensively detailed rebuild of an ax-5 tranny. I haven't found one thru all of my searches on someone detailing this particular tranny. Will update this post after I get the new parts in. Thanks to MeanMax for your help so far and hope to get more advice from you later.
Roadyy is offline
Replacing slave cylinder on 4cyl. YJ JayIV YJ Wrangler Technical Forum 7 05-14-2012 12:35 PM
Replacing external slave cylinder Rcajun TJ Wrangler Technical Forum 1 10-16-2009 10:38 AM
replacing clutch slave cylinder 93 4.0 Nate M YJ Wrangler Technical Forum 6 07-02-2009 07:53 AM
Replacing Slave Cylinder bcshome YJ Wrangler Technical Forum 19 02-15-2009 11:42 PM
Replacing the Slave Cylinder - master too? Duncan71 YJ Wrangler Technical Forum 13 07-28-2008 01:23 PM
