Replacing Rear Main Seal - JeepForum.com
post #1 of 6 Old 11-05-2012, 08:01 PM Thread Starter
OneWhiteDoor
1987 YJ Wrangler
So just bought this 87 Wrangler 4.2 with 118000 miles on it and after going through and tinkering with the carb and other issues to get it running nice, I have noticed that the rear main crank seal is leaking pretty good.
How do I change it without dropping the tranny?
OneWhiteDoor is offline
post #2 of 6 Old 11-05-2012, 08:10 PM
rocketboy
rocketboy's Avatar
Do some searching on the site. There's plenty of threads dealing with this. Basically, you drop the pan and remove the bottom half of the rear crank bearing and remove it in two pieces. The Haynes manual tells you how as well.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #3 of 6 Old 11-05-2012, 10:19 PM
jokerchief462
Here are a couple of Utube videos Part I/II shows you all with some pretty good tips.
jokerchief462 is offline
post #4 of 6 Old 11-05-2012, 10:38 PM
sdotcarter
Welcome to the forums. Your problem is common, try using search Google: "site:www.jeepforum.com then your search terms"
Then check the FAQs.
sdotcarter is offline
post #5 of 6 Old 11-06-2012, 05:04 AM
Louie4
All of the above. I've replaced mine too many times but the seal I had most success with was the single lip. The double lip ones always seemed to leak right after. Of course maybe I was not doing it right.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 6 Old 11-06-2012, 10:27 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Dirty but satisfying job. Make yourself a brass punch from a brass dowel rod, that way when you punch out your old seal from the block, you minimize the risk of damaging critical surfaces. Use a Felpro one-piece pan gasket, and when you remove all the pan bolts, punch them thru a piece of cardboard that you have drawn out the gasket outline on so that you put them back in the right holes. There are different lengths and sizes involved, some are stud top bolts, etc and it's best to get them all back in the right holes. The cardboard trick will solve that issue. The 4 cylinder requires pulling the tranny, but you can do it with the tranny in on the 6 cylinder. If the videos and threads you find do not seem to be adequate, post back in and I'll help you search for more threads.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
