replacing power steering return hose problem - JeepForum.com
post #1 of 2 Old 07-15-2013, 01:34 PM Thread Starter
metalhead
2011 WK
94 wrangler 2.5L 5spd. I need to replace the power steering return hose that goes from the reservoir to the steering gear. Has anyone done this and can give me some tips. There is not a lot of room and I could not budge the nut at the steering gear. I soaked it in rust penetrant. I tried using a flare nut wrench and a regular wrench and just could not get enough leverage on the nut to bust it loose. Any ideas would be greatly appreciated.
metalhead is offline
post #2 of 2 Old 07-15-2013, 10:57 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I've not personally had this problem, but you may have to just pull the gear box to a point where you can get leverage. It may be more of a PITA than its worth.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
