Replacing Oil Pan Gasket How Hard? - JeepForum.com
post #1 of 6 Old 01-17-2010, 01:05 PM Thread Starter
Urb4nTr0ll
I need to replace this gasket, and wondering if it is a difficult job.
I'm assuming all I have to do is remove the oil after I drain the oil and then take out the old gasket and put in the new one.
Is there anything that I'm missing?
*I want a half hardtop for my Jeep.
*I'm starting to love my '90 Jeep.
*My Jeep does not get me laid, but who cares.
Urb4nTr0ll is offline
post #2 of 6 Old 01-17-2010, 01:09 PM
dream911tommy
not hard just a pain kinda, wear clothes u dont care about as some oil will most likly spill on you, also go with the rubber gasket over cork imo, they move around a little during the job, so if possible an extra set of hands is nice to hold up the pan, if ur going this far an its the 4.2 u should bang in a new rear main seal at the same time its about an extra 10 mins but worth it if urs is leaking
04 tj columbia 35s a small lift and beer
3 yjs, one left thats a long 4link project 2 sold.
86 911 carrera too much stuff to list and alot closer to the ground
dream911tommy is offline
post #3 of 6 Old 01-17-2010, 01:24 PM Thread Starter
Urb4nTr0ll
It is a 2.5 4 cylinder engine. Thanks for the advice. I had no idea there were two type of gaskets.
post #4 of 6 Old 01-17-2010, 01:34 PM
Apollo12227
Very strait foward. Drain oil, remove pan bolts, drop pan, clean out pan, slip on the new sill, rvt where it says to rvt...
I would definatly recomend replacing the rear main sill at the same time. As stated it adds about an extra 10 minutes and requires no special tools. Do a google or forum search for "jeep rear main sill replacement".
Good luck let us know if anthing comes up.
Apollo12227 is offline
post #5 of 6 Old 01-17-2010, 01:35 PM
bigbelman2009
this is cake. i did this not too long ago on mine. drain the oil, take out the million bolts holding it in then take the old gasket off, put new one on(i used rtv with mine also) then put bolts back in and change oil filter and put new oil in
bigbelman2009 is offline
post #6 of 6 Old 01-17-2010, 05:32 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Just don't go RTV crazy. If you ooze it into the pan TOOO much it will break off eventually in clumps and clog your screen intake for the oil pump causing your engine to go oit starved. RTV is good for this seal, but in moderation!!
hotelconucc93 is offline
Replacing Oil Pan Gasket BYuen TJ Wrangler Technical Forum 3 11-28-2007 07:11 PM
Replacing D44 Gasket ?'s joppermann TJ Wrangler Technical Forum 2 08-02-2007 02:35 PM
replacing oil pan gasket, do i use gasket sealer/maker? spinnjase TJ Wrangler Technical Forum 6 03-02-2007 08:13 PM
replacing head gasket sandman'sjeep YJ Wrangler Technical Forum 9 06-20-2006 04:29 AM
replacing tranny pan gasket? new2jeep YJ Wrangler Technical Forum 3 08-07-2003 05:07 PM
