Replacing Master Cylinder - JeepForum.com
post #1 of 79 Old 01-30-2012, 09:36 PM Thread Starter
cstone94
This is going to be a thread of my adventure in replacing my master cylinder in my 1995 YJ 2.5 with 204,xxx miles. I bought the Jeep and noticed an area where it looked like, water, or some type of fluid leaking onto the drivers side floorboard. It wasn't water.
Here's a picture of the spot, and the small rust hole it created:
Here you can see where it's leaking at the firewall (Notice the lovely corrosion):
I replaced the clutch about 5 months ago, and it started to get a little soft about 2 weeks ago, then it finally hit the floor, no resistance. Checked the master cylinder, no fluid, topped it off, still nothing, so I guess air got in the line. I let it sit for a while, and kind of forgot about it. Tonight I decided to go grab the part, and get started.
I started by disconnecting the cotter pin, and moving the plastic rod from the pedal.
Then I started to undo the nuts on the inside of the engine bay, near the reservoir.
After fighting to get to the pesky things, It came off.
Comparison (Old vs New):
I have a few questions. Notice in the next to last picture. How do I get the line off of the master cylinder housing? Is there a special tool?
Any tips for this would be great and if anyone has any questions for conquering this I'd love to help.
cstone94 is offline
post #2 of 79 Old 02-01-2012, 06:53 AM Thread Starter
cstone94
anyone know how to get the line off the housing in the next to last picture?
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #3 of 79 Old 02-01-2012, 07:21 AM
bigbossd1030
That hose is held in with a rollpin. Push or drill out the pin pull the hose out and replace the o ring. If you drill the pin replace it too. Be carefull not to use a bit that is larger than the pin. You take the risk of damaging the hose inlet.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 79 Old 02-01-2012, 10:40 AM
jeepjerryp7m8
1982 CJ8
Yep a roll pin holds that fitting in. I wouldn't drill it (your choice) just use a proper sized punch and tap it out. Your new M/C should have come with a new pin and O ring.
Jerry
jeepjerryp7m8 is offline
post #5 of 79 Old 02-01-2012, 11:16 AM Thread Starter
cstone94
I don't have taps, any alternate?
11' F250 - DD
cstone94 is offline
post #6 of 79 Old 02-01-2012, 11:17 AM
pasinbuy
When he said tap it out he meant to tap on it to get the pin out. You should of disconnect the line before removing the MC. So be careful not to break anything.
Make sure that you bench bleed the new MC.
pasinbuy is offline
post #7 of 79 Old 02-01-2012, 11:21 AM
lukeh
A small flat head screwdriver, they slide right out. You want to push it from the drivers side toward the passenger side. Preferably before you unbolt the mc from the tub.
lukeh is offline
post #8 of 79 Old 02-01-2012, 11:40 AM
jeepjerryp7m8
1982 CJ8
Oh, and start the new pin in the new M/C while it is on the bench, much easier than trying while mounted on the Jeep. When you drop the pin (and you will) it will be gone forever.
Hold the pin in a needle nose pliers with one hand and a punch with the other hand and lightly tap the pin almost half way into the hole (use your third hand for this). Mount M/C to firewall insert fitting with new O ring then drive pin the rest of the way.
Should have added, first walk to the hardware store with new roll pin in hand and buy a couple extra, I have found that using the same diameter and a little longer makes life MUCH easier.
Jerry
post #9 of 79 Old 02-01-2012, 01:25 PM Thread Starter
cstone94
What do you mean by bench bleed? I got the mc off, got the pin out replaced o ring, inserted line, put.in pin, tightened it back, filled it up, waited for fluid to leak from slave bleed hole. Put the screw in. No pressure at the pedal.
11' F250 - DD
cstone94 is offline
post #10 of 79 Old 02-01-2012, 02:57 PM Thread Starter
cstone94
Okay, so I did the gravity bleed. I started it up, started pumpin the clutch, nothing there still. Looked under the turd and its leaking. the hood was open so I spotted it pretty easily.
I can push the line down, and it'll stay, if I push in the clutch it pops out and starts leaking... Any ideas?
cstone94 is offline
post #11 of 79 Old 02-01-2012, 04:34 PM Thread Starter
cstone94
Anyone? Trying to get this done tonight!
cstone94 is offline
post #12 of 79 Old 02-01-2012, 04:44 PM
jeepjerryp7m8
1982 CJ8
Remove the fitting, take a picture of the O ring and fitting and post back. It looks like you didnt get the sitting seated all the way in.
Did you get the O ring into the groove? Can you grab the fitting and pull it out? Drive the pin half way out push the fitting all the way in and drive the pin back through.
Jerry
post #13 of 79 Old 02-01-2012, 04:48 PM Thread Starter
cstone94
I got new pins, and struggled to get the one that would fit in there. It's pretty hard to get out. I lost the O Ring, went to Advanced, and bought a HELP set. threw two on there. maybe I need to do something different?
cstone94 is offline
post #14 of 79 Old 02-01-2012, 04:50 PM Thread Starter
cstone94
And the pin isn't gonna be easy to remove...
11' F250 - DD
cstone94 is offline
post #15 of 79 Old 02-01-2012, 04:50 PM
jeepjerryp7m8
1982 CJ8
You have 2 O rings on the fitting? Pull the fitting get a pic and post back up.
Jerry
Replacing master and slave clutch cylinder SKIDOG74 YJ Wrangler Technical Forum 3 07-15-2011 03:50 PM
Replacing the Master Cylinder??? i MRS. TRUE YJ Wrangler Technical Forum 1 07-12-2010 11:18 AM
Replacing the Slave Cylinder - master too? Duncan71 YJ Wrangler Technical Forum 13 07-28-2008 01:23 PM
HELP-Replacing Master Cylinder Stiffler YJ Wrangler Technical Forum 3 11-15-2005 10:14 AM
Replacing clutch master cylinder tufmar YJ Wrangler Technical Forum 17 03-15-2004 03:12 PM
