Replacing Hydraulic Clutch Line - JeepForum.com
post #1 of 4 Old 01-15-2009, 08:05 PM Thread Starter
floridaknight
I have a 93 Wrangler Sport. On the way home from school, I lost all pressure in the clutch. When I pulled into a parking lot, I looked underneath the Jeep to see liquid dripping from the bell casing. The culprit was a metal clutch line. Would this be the clutch hydraulic line? If so, can it be replaced without having to drop the transmission? I was hoping for a "quick" repair in the parking lot. Thank you all in advance for your insight! I am completely ignorant when it comes to mechanical repairs of the Wrangler.
floridaknight is offline
post #2 of 4 Old 01-15-2009, 08:12 PM
SteveJcoYJ
if its the line that runs from the clutch master to the slave cylinder, then yes you have to correct line
if you have an external slave you can replace the line without dropping the trans, i don't remember if its 94 on or 93 on for ext slaves. if you don't have the external slave, there will either be a black thing mounted outside of the transmission housing on the drivers side or there won't be, then i believe you will have to drop the trans.
SteveJcoYJ is offline
post #3 of 4 Old 01-15-2009, 08:46 PM
befumo
Yes its hydraulic. Thought it was 94-95 have external slave cylinders?
Just bought the same part from the dealership usually runs around $170-200, got mine for $177. Have found non on the internet for internal slave cylinders.
befumo is offline
post #4 of 4 Old 01-18-2009, 07:29 AM Thread Starter
floridaknight
Thank you two for your responses. Unfortunately, I am going to have to remove the transmission.
Need a 94 yj clutch hydraulic line! Help..... midnightc2 YJ Wrangler Technical Forum 5 01-19-2010 11:43 PM
93 Clutch hydraulic line shamsun YJ Wrangler Technical Forum 1 11-07-2008 09:51 AM
Hydraulic Clutch Line Flat Black YJ Wrangler Technical Forum 8 03-08-2007 03:19 PM
Hydraulic clutch line DaOne TJ Wrangler Technical Forum 2 07-05-2006 09:20 AM
hydraulic clutch line/should i cut it johnny1720 YJ Wrangler Technical Forum 8 12-11-2003 06:16 PM
